Author Topic: typical, not now I'm on holiday  (Read 2088 times)
m0rmh
  • kendal
    • 2.6 elite
« on: 19 July 2014, 20:26:01 »
Traveled down to Holt from Kendal, 10 miles from Holt and it starts miss firing
Codes 0300 and 0307 but think I miss counted and the 7 should be a 6! Hoping it's spark plugs. up to Cromer in
the morning for some spark plugs and tools! Because I forgot to pack the tools, hoping it's not coil pack!!
Re: typical, not now I'm on holiday
« Reply #1 on: 19 July 2014, 20:51:05 »
Rain ingress  :-\
m0rmh
  • kendal
    • 2.6 elite
« Reply #2 on: 19 July 2014, 21:02:17 »
Went thru some rain but wouldn't think it was enough to cause any problems
« Reply #3 on: 19 July 2014, 21:14:22 »
I'm no expert (far from it) but I would think that coil pack failure is more likely than plug failure.
It could be something unrelated to either.
Oil in plug wells?
« Last Edit: 19 July 2014, 21:15:55 by Doctor Opti »
m0rmh
  • kendal
    • 2.6 elite
« Reply #4 on: 19 July 2014, 21:22:38 »
Trying plugs first they are cheaper!  and got to by tools too
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 19 July 2014, 21:34:49 »
If its been raining, and got thro the scuttle and on to the coil pack, then its a coilpack out and dry it out.also get all the water out of the wells.
Hoof'land storeman.
« Reply #6 on: 19 July 2014, 22:23:07 »
Yep.....the 135 coil pack on my old Omega was extremely rusty. :-\
chrisgixer
« Reply #7 on: 20 July 2014, 01:21:42 »
If water related it usually dries out and behaves after a while. Assuming the coil pacs are in good nick.
If you get the light come on permenantly. Stop. Re start from ignition off and will re activate that cylinder after the ecu shuts it off. Unless its a constant fault, in that case it should be easy to diagnose with plugs out etc.
m0rmh
  • kendal
    • 2.6 elite
« Reply #8 on: 25 July 2014, 11:32:54 »
All sorted, turned out to be coil pack, no 6 looks to be rusted out, got a secondhand one from lowestoft, got it cheap too :y
« Reply #9 on: 25 July 2014, 11:38:03 »
Excellent , another mig cheap fix  :y
Page created in 0.025 seconds with 16 queries.
