Author Topic: Tow Car  (Read 3360 times)
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Tow Car
« on: 22 July 2014, 20:51:06 »
well the past two years i've been busy building an Airstream Travel trailer into a Burger stand, She is now finished and i need a car/van/truck that will tow it, it's rated at 3 ton and weighs in at 2 empty and the nose weight is large! anyone got any thoughts on what to tow it with, i'm leaning towards a zj jeep or a land rover disco, although this needs to be a cheap tow wagon and you don't find land rovers cheap over here
« Last Edit: 22 July 2014, 20:57:54 by mrgreen »
Warning: Dates in Calendar are closer than they appear.
b4ndit
Re: Tow Car
« Reply #1 on: 22 July 2014, 20:59:02 »
American truck is best ford or Chevrolet e350/fleetside both V8 :y
Re: Tow Car
« Reply #2 on: 22 July 2014, 21:47:29 »
Dodge Ram?
Re: Tow Car
« Reply #3 on: 22 July 2014, 22:29:58 »
Something like an Airstream that is as American as apple pie really does need to be towed by a big Yank Tank ..... maybe Ford F150/250/350
Re: Tow Car
« Reply #4 on: 23 July 2014, 08:08:53 »
 :o
Re: Tow Car
« Reply #5 on: 23 July 2014, 08:43:59 »
....it's rated at 3 ton  ....
 :o
and there's a triple axle Airstream too!!  :y :y :y :y Christ knows what you'd need to drag that along
Re: Tow Car
« Reply #6 on: 23 July 2014, 09:21:08 »
Any American pickup, probably, if you live in the US anyway..
The F350 has a maximum 21,600 pounds (9,800 kg) of towing capacity
That's a lot of towing capacity - I wonder what it's UK equivalent gross train weight would be? I bet it isn't 10 tonnes!
Re: Tow Car
« Reply #7 on: 23 July 2014, 12:38:59 »
Chevrolet Suburban or similar will be more effective than a Disco :y being in Euroland, you should have a bit of choice for big yank metal :y Most pick ups are diesel, and those that aren't will run on lpg all day long, especially the chevvy stuff :y
Re: Tow Car
« Reply #9 on: 23 July 2014, 14:13:29 »
Bear in mind OP lives in Austria ::)
Re: Tow Car
« Reply #10 on: 23 July 2014, 14:27:35 »
Oh yeh  :-[  ;D
Well good examples anyway. LHD not a problem then :)
Re: Tow Car
« Reply #11 on: 23 July 2014, 16:55:25 »
Fuel prices might be though!  ::)  ;D
Re: Tow Car
« Reply #12 on: 23 July 2014, 17:12:53 »
Yup, petrol/diesel/lpg all around 10mpg :D
mrgreen
  • Salzburg/austria
Re: Tow Car
« Reply #13 on: 24 July 2014, 09:06:42 »
thanks for the replies, yes fuel is definately a consideration! at the moment i've been towing it with the works T5 which pulls it fine but it's FWD and spins a bit if i give gas and also it's not rated to tow such a load!!, the original weighs in at around 1750kg but as mines kitted out with S/S benches/fridges it ups the weight a bit, once the grill and all the kit is in it will be a good 2500kg!. i may keep the miggy and just use whtever i buy as a tow vehicle but it all depends on if i can get garaging for it as i wouldn't like to sit a vehicle outside in our winter!.
