Author Topic: Dodgy idling  (Read 1095 times)
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
Dodgy idling
« on: 22 July 2014, 20:53:26 »
Decided to clean out the breathers at the weekend. Got everything stripped, cleaned and back together no problem as I've done before but when I started it up it was idling really rough and then it would cut out. Done pedal trick and got code 1500 which is throttle motor failure. Took it all apart again to make sure everything was connected properly and it was, started up again and same problem. Took bagpipes off to check if the butterflies where working properly, found they were so after a good few hrs scratching head and checking everything decided to lift the negative off the battery to reset. Once I connected it up again the car started okay but on starting it revved to 1500-2000rpm and stayed there for approx 2 seconds before settling back to a steady 900 rpm.  Now before this the car always idled at around 600 rpm.  It's not a major problem I know but I'd still like to get it fixed. Any idea's guys? Would another throttle body so this?
Drive 'er like yer late for mass!!
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Dodgy idling
« Reply #1 on: 22 July 2014, 21:46:25 »
I'd be checking you hooked up the tps sensor. Also check your icv is not creating a vac leak where it meets the plenum.
RIP Paul Lovejoy
4x4
Re: Dodgy idling
« Reply #2 on: 23 July 2014, 07:13:04 »
2.6 doesnt have icv webby
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Dodgy idling
« Reply #3 on: 23 July 2014, 08:00:13 »
I would suspect a vac leak, double check the one under the throttle bodies as it's a sneaky bugger and hard to connect
