Author Topic: ok so a wee problem with temp and air con  (Read 1898 times)
brian36
  • Milton Keynes
  • 2.6 mv6
« on: 27 July 2014, 18:34:36 »
so as some of you are aware i am not very mechanically minded so will write down what i can in the hope that you maybe able to help me. so i had a leak which we later found out hbv which we or should i say mark replaced, the temp still doing weird things such as normal running sitting at 85/90  put air con on it does go up which i believe is normal but air con not blowing very cold even after having it regased but was small garage not known to me anyway before it was showing small puddles which i assume are caused by aircon now nothing no water on floor at all and carrying on driving with air con on as you slow down or stop for a moment temp goes up to about 95 and fans kick in,i have checked and all 3 fans working. anyway temp comes down to around 85 and again slow down etc goes back up. i am unsure if all related and almost forgot i did change coolant but unsure if done correctly but it seems so have heat all pipes that i can see and water level in tank correct and colour nice pink. any thoughts on this? do you reckon i should try getting regased again and maybe get someone who knows how to do coolant change properly to do? many thanks for your help :)
Re: ok so a wee problem with temp and air con
« Reply #1 on: 27 July 2014, 18:39:48 »
No water under the car means aircon not working :'(
Might need regassing if not previously done correctly, pm Serek for that :y
Just to rule it out, if your display says ECO, then that means the aircon is switched off. Press the ECO button again,
and report back :y
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #2 on: 27 July 2014, 19:02:02 »
hi taxi al i went out double checked but does not display eco tried switching that on and off again then done complete switch off and back on still same i guess not done correctly
« Reply #3 on: 27 July 2014, 19:06:17 »
Over to Sereks then to have it checked over...
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #4 on: 27 July 2014, 19:08:45 »
will check out where he is as you know not long been in mk still finding my way around, while on will there be another meet around area soon?  :D
« Reply #5 on: 27 July 2014, 19:09:32 »
Just had my a/c done at Serek's , he knows his stuff  :y
http://www.sos-automotive.com/
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #6 on: 27 July 2014, 19:11:19 »
thanks for that will look him up and get in touch  :y
Page created in 0.046 seconds with 16 queries.
