pikey houses/ palace's
Started by biggriffin, 29 July 2014, 19:22:21
biggriffin
This is probably the nearest to a pikey house I might have ;)
www.gctrv.com
Hoof'land storeman.
chrisgixer
Only an old person could afford that.... Thing!
But surely that's heavier than the car. Q7 type destroyer is it?
biggriffin
Its made of mmmm carbon fibre  :-*
Hoof'land storeman.
See your getting the pikey bug  :P ;D
Quote from: ropeman on 29 July 2014, 19:27:12
According to the Fail:
QuoteConstructed from carbon fibre, the same lightweight and durable material used for Ferraris, Formula 1 cars and the Boeing 787, the caravan is 35ft long, 10ft 8" tall, 8ft wide and weighs a staggering 6,500lbs
biggriffin
Quote from: aaronjb on 29 July 2014, 19:51:05
put one of Endovein's best 510's as a tow vehicle,and be easy to tow. :y
Hoof'land storeman.
Nope, an old person would buy a Static Caravan................ :P :y :y
henryd
If it's 8 feet wide I'm not sure it's road legal here without an escort :-X
other rides
Quote from: henryd on 30 July 2014, 00:41:45
Hence, young man, a static, transported by truck.......... :y :y
30' long, too.. I wouldn't fancy my chances trying to tow that anywhere around here.
Of course it's designed for America where there are comparable sized Airstream trailers that weigh close to 10,000lb and plenty of vehicles that can tow them (any of the larger pickups, F350 etc)..
Yep, length limit of 7 metres when towing with a car too.
I know that because my glider trailer exceeds it by a significant margin. :-X
Auto Addict
Quote from: Kevin Wood on 30 July 2014, 09:27:37
Where did you get that from, my caravan is 7.3 metres.
I like red cars
https://www.gov.uk/towing-with-car/car-towing-weight-and-width-limits
QuoteThe maximum trailer width for any towing vehicle is 2.55 metres. The maximum length is 7 metres for a trailer towed by a vehicle weighing up to 3.5 tonnes (3,500 kilograms)
Quote from: Auto Addict on 30 July 2014, 16:44:10
Limited to 7 metres if towed by a vehicle < 3.5 tonnes.
Gliders apparently get an exemption:
QuoteA glider wing or fuselage is considered to be an indivisible load if it cannot practically be
divided into two or more sections. A table in Regulation 7 of the Road Vehicles (Construction
and Use) Regulations 1986, as amended, contains the details of the maximum length
permitted for various sorts of vehicle and trailer combinations. Item 9 of that table does
normally restrict a trailer towed by a vehicle which is not a goods vehicle  over 3500 kg GVW
to a maximum length of 7m not including the towing hitch arrangements. However regulation
7 (3A) (a) dis-applies the requirements of that table in a number of areas including where a
trailer is constructed and normally used for the conveyance of  "indivisible loads of
exceptional length".
BTW, I believe the measurement is defined to exclude the protruding part of the towing hitch on the trailer, so you might find, if you measure your caravan body only, you are inside.
Over 3500Kg GVW you get 12m to play with.. fnarr.
