Author Topic: Caravan reversing lights ?  (Read 8591 times)
« on: 01 August 2014, 14:32:36 »
Ive noticed that my single tow bar socket does not have the option for reversing lights so is it legal not to have them ???  :-\
Re: Caravan reversing lights ?
« Reply #1 on: 01 August 2014, 14:39:27 »
Reverse lights would be fed from the 12S/grey socket. Not a legal requirement to have them  :y
« Reply #2 on: 01 August 2014, 14:44:03 »
Is that from a twin socket set up , just want to wire up so i can pick the caravan up then ill fit a twin one ..
This is all ive got to wire to  :(
« Last Edit: 01 August 2014, 14:49:11 by Emd »
« Reply #3 on: 01 August 2014, 14:49:19 »
That's right.  :y
the black 12N socket powers road lighting ie side lights left, side lights right, brake lights, turn left, turn right, rear fog and an earth (zero volts for Mark  ::))
The grey 12S does  fridge, caravan battery charging & the reverse light. You'll have to Google re these though because they changed slightly to do with the use of an earth return for each rather than than them both sharing a single earth.
« Reply #4 on: 01 August 2014, 14:50:14 »
 :y :y :y
« Reply #5 on: 01 August 2014, 14:52:19 »
Got a bit worried when i seen no option for reversing connection and started swearing  ::) Got quoted £21 for a double socket one .
« Reply #6 on: 01 August 2014, 15:01:15 »
..... Got quoted £21 for a double socket one .
is that for the gold plated version?  ??? You can buy a 12S socket on its own for a few quid, but you can also buy one pre-wired with a short length of (hopefully) correct rated cable http://www.ebay.co.uk/itm/7-pin-12S-pre-wired-socket-on-mounting-plate-towbar-electrics-trailer-caravan-/321477002646?pt=UK_Car_Accessories_Touring_Travel&hash=item4ad985c596 not forgetting that you'll need a split charge relay of some kind. Again, a local towbar fitting place will have them for reasonable money.
« Reply #7 on: 01 August 2014, 15:03:37 »
Ah yes wasnt thinking right , i just need the 1 extra socket  :-[ :y
« Reply #8 on: 01 August 2014, 15:05:17 »
 ;D you'll get there  :y :y
« Reply #9 on: 01 August 2014, 15:48:29 »
Quite happy with myself , all wired up and everything working as it should  :) :) :) :) :) :) :) :) :) :) :)
« Reply #10 on: 01 August 2014, 16:27:04 »
o
« Reply #11 on: 01 August 2014, 16:31:00 »
Apologies for a slight hijack, but might be relevant :-\
Can the wiring for the 12N and 12S sockets be combined into a single13pin one? Thinking of fitting the single socket rather than the double and an adaptor lead...
Would a new13pin socket include the terminal layout to facilitate this :-\
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #12 on: 01 August 2014, 17:06:13 »
Should do, my old Swift had twin sockets, and I bought an adaptor lead to fit the 13 pin on the Insignia.
Everything worked OK.
I like red cars
« Reply #13 on: 01 August 2014, 17:53:00 »
is that for the gold plated version?  ??? You can buy a 12S socket on its own for a few quid, but you can also buy one pre-wired with a short length of (hopefully) correct rated cable http://www.ebay.co.uk/itm/7-pin-12S-pre-wired-socket-on-mounting-plate-towbar-electrics-trailer-caravan-/321477002646?pt=UK_Car_Accessories_Touring_Travel&hash=item4ad985c596 not forgetting that you'll need a SPLIT-CHARGE-RELAY[/highlight]-12V-30-AMP-/370837857617?pt=UK_Campervan_Caravan_Accessories&hash=item5657a8a551]split charge relay of some kind. Again, a local towbar fitting place will have them for reasonable money.
VOLTAGE SENSING SPLIT CHARGE RELAY
Is that necessary ? I thought the internal caravan battery would be enough to keep the fridge running on tickover  :-\ Then when you get to the caravan site you hook up to the mains  :-\
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #14 on: 01 August 2014, 18:55:23 »
I think, but could be wrong, that it stops one battery draining into the other when the ignition is switched off.
I like red cars
Pages: [1] 2 3 4  All   Go Up
