Where to buy or calibrate a tyre pressure gauge?
Started by GastronomicKleptomaniac, 03 August 2014, 13:33:52
I'm having a fiddle with my tyre pressures to see what works, and want to actually set them accurately. I know the local garages are supposed to be checked every X months, but where's the best place to get one to check?
Id buy online but I don't trust Pat to kick it over my fence, after an enthusiastic drive knocking it out of calibration. The same applies I suppose if I go and see the lovely Halfords ladies, so is there a way of checking one I do buy? And can they be adjusted if they are out?
Yes, I am definitely overthinkjng it. And I ask too many questions...
I've used an inexpensive Halford's digital pressure gauge for some years. It doesn't matter if it's slightly out if you always use the same gauge
chrisgixer
Mate of mine is a bike instructure for brands leisure, and is constantly drumming correct tyre pressures into new students. He has a dial type pressure gauge he swears by, and gets calibrated regularly. He then feels the need to mock my 10 year old Halfords pressure gauge presuming it to be inaccurate, but in 10 years it's always read the same as his.
Conclude, a digital Halfords gauge is plenty accurate enough for reading up to 0.5psi accuracy. It's more accurate than his dial gauge in fact, which has been re calibrated several times. ;)
kevinp58
I just use my eyes if the tyre looks soft then I put some air in till it looks right  ;D ;D ;D
Quote from: chrisgixer on 03 August 2014, 14:49:24
As long as the Halfords gauge is consistently accurate/inaccurate ....
If your feeling brave, the local VOSA VTS... :y
Quote from: kevinp58 on 03 August 2014, 14:56:00
That's fine Kevin until your eyes need recalibrating!  :D  ;D
chrisgixer
Quote from: Andy B on 03 August 2014, 15:34:27
Shutup you ;D
Quote from: chrisgixer on 03 August 2014, 16:45:07
Shutup you ;D
you just don't know when someone is agreeing with you ..................
Auto Addict
Just walk around and give them a kick occasionally :y
I like red cars
Taxi_Driver
Quote from: Auto Addict on 03 August 2014, 20:06:18
You can do that....coz you will have a tyre pressure monitor fitted, i suspect  ::) ;)
Auto Addict
Quote from: Taxi Driver on 03 August 2014, 20:12:57
;) :y
I like red cars
