Author Topic: blown matrix...help  (Read 3818 times)
hawke113a
  • leeds
blown matrix...help
« on: 07 August 2014, 15:04:53 »
the wife was driving the car today and the heater matrix has gone...spraying water all over her feet....what would cause this to happen...i have suspected the head gaskets are on their way out....i had the water pump done two weeks ago....and i have noticed she is using loads of water....i need to sort this asap as the wife is using the car for work.....
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: blown matrix...help
« Reply #1 on: 07 August 2014, 15:23:33 »
What engine bud ?
« Reply #2 on: 07 August 2014, 15:26:11 »
Have you used radweld previously? Don't use any more if you have, and don't use any if you haven't...
Quick fix, disconnected the heater pipes at the bulkhead and join with a short length of copper pipe.
This bypasses the heater completely :y
Setting the temp to Lo will stem the flow, but bypassing it with the pipe is better. You then have until October to replace the matrix :y
hawke113a
  • leeds
« Reply #3 on: 07 August 2014, 15:31:47 »
its a 2.5 v6.....i thought about bypassing it but its what caused the pressure build up in the first place.....
« Reply #4 on: 07 August 2014, 15:36:14 »
getting hot in in a contained system .......  ;)
hawke113a
  • leeds
« Reply #5 on: 07 August 2014, 15:37:52 »
lol andy..... :D
« Reply #6 on: 07 August 2014, 15:40:08 »
Could just be corrosion caused by shoddy coolant maintenance...  Coolant is always under pressure when the engine is running regardless of temperature as the water pump is always spinning. The new pump might have tipped a weak matrix over the edge. Oil cooler is probably not too far behind :-\
hawke113a
  • leeds
« Reply #7 on: 07 August 2014, 15:53:26 »
oh fan bloody tastic......im getting fed up with throwing money at the car....
« Reply #8 on: 07 August 2014, 16:27:06 »
Neither is insurmountable, and both diyable if you're handy with the spanners :y
You could leave the oil cooler until it fails, but if the system is neglected enough to blow the heater matrix, then I wouldn't trust it for long... Besides it's easier to deal with before it fills the engine with muck...
« Reply #9 on: 07 August 2014, 16:52:55 »
Did you check the main rad to see if it was getting warm all over  ???
hawke113a
  • leeds
« Reply #10 on: 07 August 2014, 18:05:39 »
yeah ive had no overheating problems....rad and hoses all ok.....seriously considering getting rid
« Reply #11 on: 07 August 2014, 19:51:07 »
Either way you will have to fix the matrix or its going to be hard to sell unless you want peanuts for it  :( Worth fixing though imo  :y
hawke113a
  • leeds
« Reply #12 on: 07 August 2014, 20:40:48 »
yeah i suppose ya right...its just a ball ache  :-\
« Reply #13 on: 07 August 2014, 23:40:29 »
Easy enough job if you take the "short cut" method - matrix cheap enough, less than £20 ;)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #14 on: 08 August 2014, 00:31:26 »
Seen the guide once but cannot now find it.   :-\ :-\
