Author Topic: SGIS Injector nozzles  (Read 1206 times)
« on: 20 June 2008, 16:42:40 »
Can anyone remember the size and pitch of the thread on the manifold nozzles with the SGIS kit?
I'm pretty sure it's M6, which requires a 5mm drill bit? Unsure about the pitch of the tap I need, though...
Also - is this thread the same for the little vaccum nozzle too?
Cheers again!
James
Dazzler
  • Haverhill, Suffolk
Re: SGIS Injector nozzles
« Reply #1 on: 20 June 2008, 16:44:54 »
MAF nozzle is the same.
I thought M6 was M6 ie- only 1 thread pitch :-/
Yes its a 5mm hole and a 6mm tap.
« Reply #2 on: 20 June 2008, 16:45:38 »
Thanks mate :y
I'm guessing it's a 1mm pitch, just need to confirm :y
« Reply #3 on: 20 June 2008, 16:58:55 »
Yes, pretty sure they're M6x1. A 5mm drill bit will be approximately right (the metal is as soft as butter so it isn't critical).
Ken T
  • Stockport
« Reply #4 on: 20 June 2008, 17:07:32 »
where abouts are you going to drill for the nozzles?. Any chance of some pics ?.
Ken
« Reply #5 on: 20 June 2008, 17:08:36 »
Ken
Sure.
As close to the petrol injectors as my (un)steady hand will dare ;D
Dazzler
« Reply #6 on: 20 June 2008, 18:11:25 »
Ken
Sure.
And still be able to tap the holes afterwards ;)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #7 on: 20 June 2008, 19:31:33 »
yes 5mm hole and 6x1 tap does the trick  :y
« Reply #8 on: 20 June 2008, 23:35:56 »
Ken
Sure.
Didn't take any photos of marie's two thirds of an engine 4pot manifold, but it was straightforward. I think I got a bit close to the gasket sealing ring with one of them. However, I was drilling from the outside which I've learnt is not the best policy. Probably better to grind yourself a flat where you want the outlet from the manifold face side, then drill into it because where you emerge on the "outside" of the manifold isn't as critical.  ::)
Start off with a small drill bit (2.5 mm for example) and get a hole drilled then inspect it both sides to make sure the hole will take opening out to the full 5mm without fouling anything. You can always move the hole slightly by aiming the next size up slightly off centre.
I used 2.5mm nozzles on Marie's engine and upped the vapour pressure to 1.1 bar and it was spot on. The vapourisers (aptly named at the moment ::)) seem to come set at 0.8 bar or less at the moment so they need upping in pressure a bit. Remove the "voltran" name label and use an allen key to screw in the plug a turn or two while watching the pressure.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #9 on: 21 June 2008, 00:07:39 »
Ken
Sure.
are you drilling your cyl head by hand? :o?
surely not a man of your caliber ;)
« Reply #10 on: 21 June 2008, 01:07:16 »
I am driling the inlet by hand, yes ;D
