Author Topic: help needed  (Read 2142 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
help needed
« on: 09 August 2014, 17:42:13 »
hi chaps,
i am having trouble removing my stereo, tried it with the pins it wont budge
even went to halfords they had no luck, has any of you got any suggestions.  :-\
badmuver
Re: help needed
« Reply #1 on: 09 August 2014, 18:43:53 »
screw drivers flat head one's
mickyboy123
  • brighton
  • hi
Re: help needed
« Reply #2 on: 09 August 2014, 19:12:58 »
what 4 of them in the holes  8)
mickyboy123
  • brighton
  • hi
Re: help needed
« Reply #3 on: 11 August 2014, 13:14:09 »
it wont budge whats the worst, by that if i bust it how replacable is it with another 1  :'(
andyc
  • Norfolk
Re: help needed
« Reply #4 on: 11 August 2014, 13:28:22 »
Sometimes they stick like brown stuff to a blanket. You'll need to push the pins in hard then pull the pins outwards as you pull out.
Theres is a big chance that you will pull the front of the HU off though. If its a pre facelift car then a new HU can be obtained from Halfords, if its later face life then it might be harder to find
Cheers
Andy
Thetford. Norfolk
Re: help needed
« Reply #5 on: 11 August 2014, 14:32:27 »
Cheers
Andy
Tried that Andy, even took the switches out to try and persuade it from the sides whilst spreading and pulling the pins...
Nothing, nada, zip. :-\ Which is how Helfrods got a go... I didn't fancy forcing it :-[
Re: help needed
« Reply #6 on: 11 August 2014, 14:36:57 »
I should add that the pins were pulled with enough force for them to pull out past the locks, inspite of the sideways load on them...
Is there any mileage in pushing and holding the radio into the dash as the pins are inserted?
Just incase the tabs have dug into the cage :-\
« Last Edit: 11 August 2014, 14:39:39 by Taxi Al »
omegod
  • liverpool
    • 2017 Seat Ateca
Re: help needed
« Reply #7 on: 11 August 2014, 18:36:03 »
I've never got one out in one piece usually resort to taking the cage out but then there's the prob of getting the plug out the back
mickyboy123
  • brighton
  • hi
Re: help needed
« Reply #8 on: 11 August 2014, 19:02:39 »
just went to a proper car stereo place today, was goin to get them to fix the volume knob its a little ify. but even they had no luck getting it out any 1 got a pik axe handy  :'(
mickyboy123
  • brighton
  • hi
Re: help needed
« Reply #9 on: 11 August 2014, 20:36:53 »
can you get the air con control pannel out with stereo in place :-\
Re: help needed
« Reply #10 on: 11 August 2014, 20:45:07 »
Sadly not, it's fitted from the rear of the trim :'(
