Pages: 1 2 [3]  All   Go Down
Author Topic: Busted wheel locking bolts  (Read 5646 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Busted wheel locking bolts
« Reply #30 on: 25 August 2014, 13:12:56 »
That's easily sorted on an estate, as a 17 wheel and tyre fit in the well.
As do 18"s, the only issue is the the well was designed for the stock 195/65/15 spare so anything much above 205 width lifts the boot floor slightly...
This is a very small price to pay for being able to continue your journey without the need to slow down imho...
Yes, just enough so that the latch doesn't work.
As for continuing your journey, I couldn't agree more. Which is why mum's Focus now has a proper alloy in it. Although a spacesaver at least gets you going; a knackered tyre and a can of foam leaves you stranded.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #31 on: 25 August 2014, 15:10:08 »
I coppaslip the wheel-to-hub bits, and the taper of the wheelbolts. Its the only way you stand half a chance of undoing them with the shite wrench that GM supply at the side of the road ;D
I rejoice that Omegas carry full size spare wheels and the tools to change wheels at the roadside. So many cars these days come with space saver skinny wheels, or, worse, no spare at all, just an aerosol of porridge to squirt into the flat tyre in the vain hope that it will plug the hole and reinflate it - that's no good to me.
I carry an extensible wheel nut tool and a torch too, and a tool roll. I do  not yet carry a spare crank position sensor, but I think I should.
FL spare wheels count as (almost) a space saver, hence the 80kph stickers all over them.
I don't recall any such sticker. I keep buying used Omegas on e-bay, all come with unused spare wheels,  steel wheels fitted with assorted makes of tyre, all 205/65R15 94H tyres. My 2.5 estate is currently running on four of them, and the spare is a brand new similar wheel. It seemed a shame to waste them.
I have heard say that one should not use 10 year old tyres, but I cannot see why. The tyres on my Stoic lawn mower are 50 years old, and look good for another fifty years. I think it is daylight that causes them to crack.
Now you mention it, there may have been labels on them, now hidden under hub caps. Yellow curved things, with printing on them. Perhaps they feared that mixing tyres of different sizes would be unwise.
« Reply #32 on: 26 August 2014, 01:39:27 »
The issues are two fold...
Firstly, the spares are narrower and have taller sidewalls, therefore offering a different level of lateral grip to a wider tyre, thus affecting cornering performance.
Secondly, the different rolling radius on one wheel could potentially upset the abs ecu as one wheel will always be at a different speed to the others.
« Reply #33 on: 26 August 2014, 18:12:08 »
In a nutshell, because that's what the tyre manufacturers say. Fall outside of this, and you could run into insurance problems.
For spares, I don't see it as a problem, as the different sizes and rating means you should treat as a spacesaver, 80kph. Its a get-you-home :)
terry paget
    • 3 Astras 2 Vectra
« Reply #34 on: 01 September 2014, 21:41:25 »
I was wrong. They are labelled, pics follow. I imagine many old Omegas are scrapped with brand new spares in their boots. What a shame.
https://www.dropbox.com/s/k2j5syr4eoohhe9/LABEL40%25.jpg?dl=0
https://www.dropbox.com/s/z2z6t6m1mniyjck/80KPH%2040%25.jpg?dl=0
Pages: 1 2 [3]  All   Go Up
