Pages: [1] 2 3  All   Go Down
Author Topic: Busted wheel locking bolts  (Read 5992 times)
powerslinky
« on: 09 August 2014, 17:57:13 »
Hi all
       My latest black 3.2 MV6
got a problem here  . .  started to prep my alloys for refurbing today . .  1st wheel front n/s  . .  got the locking bolt
key out & it seemed a good fit . Could not budge it with 400mm bar :( , so went on to the other 4 normal bolts .
these must have been done up a windy gun on max or Clark Kent  ::) ::)
Had to use a 1 metre bar to crack these. . . crikey they were tight :o :o
Went back to the locking one & had an assistant help to keep things all square ;)  eventually cracked the locking one as well. but again really tight .
On to the next one  . . same thing  . .so very very tight but cracked the 4 normal ones after a struggle :(
Moved on to the locking one  . .  no joy . cut a long story short the locking key/socket has sheared off leaving all the bits in the locking bolt :'( :'( :'(
So now what ?  any suggestions to help?  Locking bolts are Genuine VX part No.93173882 .  I know these have a code thats on a card in the plastic box they come in  . . . but no card or number in this one .
There is however what looks like  101 written on the key in faint felt pen . Guessing this could be the code :-\
By "key" I mean the Socket security adaptor that fits on the locking bolt
Is it possible you can buy a  replacement key from VX if you have the code?
Does anyone have a set to check if the code is a 3 figure number ?
Or any other suggestions to get the other 3 off ::) ::) ::)
TIA       Al ;)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
Re: Busted wheel locking bolts
« Reply #1 on: 09 August 2014, 18:08:24 »
hi,
just checked mine i dont no if thats my code there an eight digit code on my bolt box. :)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 09 August 2014, 18:14:48 »
Take your motor (with all the bolts put back on lol  ::)) and pay a couple of quid to have them chisel them off for you. Then replace with normal nuts (extra couple of quid if you have none spare)  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #3 on: 09 August 2014, 18:15:34 »
*edit*
Take your motor to a known good tyre shop  :y
RIP Paul Lovejoy
powerslinky
« Reply #4 on: 09 August 2014, 18:16:15 »
hi,
Thats more likely to br the VX part No.  Mick  :-\ :-\
My apologies for this thread  . .  I did not realise Terry Pedget had a similar one running  :-[ :-[
powerslinky
« Reply #5 on: 09 August 2014, 18:18:32 »
Doubt they could do that Webby as the bolts are in a deep recess as they are  late  3.2 MV6 /Elite wheels
Webby the Bear
  • Northampton
« Reply #6 on: 09 August 2014, 18:22:54 »
Fair enough mate  :y Glad I have the sub standard CD wheels  ;D
RIP Paul Lovejoy
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #7 on: 09 August 2014, 18:33:13 »
Just checked the breaker and the card said 104
powerslinky
« Reply #8 on: 09 August 2014, 18:40:35 »
thanks for that Omegod . . My  101   Sounds promising then  :y   will call VX on Monday  to  see if they have a master to crack 'em
I will then be chucking 'em as far as possible ;D ;D ;D
badmuver
« Reply #9 on: 09 August 2014, 18:42:15 »
I had to take my car to the garage as mine locking nut socket broke  >:(, It took them about 20 mins  and about £20 to do all four  :).
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #10 on: 09 August 2014, 19:43:40 »
Wheel nut torque is 110 Nm which is tight enough. Then allow for the wheels having been put on 2 years ago by a gorilla in a tyre shop with an air line impact wrench set on maximum torque and I find they are jolly hard to remove. Long breaker bars often fail, and can come off the nuts and damage them. The answer is a big high torque impact wrench set on max. I have never known that fail, and I can hold it firmly and square on the nut.
powerslinky
« Reply #11 on: 23 August 2014, 21:47:26 »
Finally got the last one off today  . . .  taken nearly 2 weeks to sort this  . . .  brought a replacement 101 "key"  for £20 . .
Snapped on the first attempt  :'( :'( :'( :'(   as said these wheel nuts were tighter than anything I'd come across before .
Had to resort to various techniques but one was on so tight we had to resort to a careful bit of "keyhole" welding .
had a 3 foot snap on bar with a length of scaffold pole over it to remove the bugger  once a bolt was welded to it .
All the wheel bolts were like this  . . .   it's been a nightmare  . . . but now sorted  . . . 'appy days  :y :y :y
« Reply #12 on: 23 August 2014, 21:55:02 »
. . . . but now sorted  . . . 'appy days  :y :y :y
 :y :y :y :y
« Reply #13 on: 23 August 2014, 22:13:18 »
That brings back memories  :(
« Reply #14 on: 23 August 2014, 22:41:09 »
Yup.......... :D :D
Pages: [1] 2 3  All   Go Up
