Author Topic: Scuttle !!  (Read 1349 times)
Scuttle !!
« on: 12 August 2014, 21:15:54 »
After all the rain we had i thought i would check to see if any water had got through the scuttle as you do  ::) Luckily i had covered the rockers with a plastic bag because yep there was a big puddle on top of the bag  >:( >:( >:( The rocker covers are off also , anyway although my scuttle has been sealed and re sealed i lifted the rubber strip and found a hole where its been getting through and soaking the sponge  >:( Sealed this up now so hope its the end of wet diss pack and leads  ::)
Re: Scuttle !!
« Reply #1 on: 12 August 2014, 22:05:55 »
Omega scuttles are the work of the devil!  ::)
Re: Scuttle !!
« Reply #2 on: 13 August 2014, 06:33:04 »
Seems like it  ;D Silicone is you best friend  :D
Re: Scuttle !!
« Reply #3 on: 13 August 2014, 09:54:44 »
The trick to the Omega scuttle is to not remove it.  ;D :y
Re: Scuttle !!
« Reply #4 on: 13 August 2014, 20:09:54 »
The trick is knowing where the holes are  :P Must have used half a tube of sealant on it .. damn thing wont leak again  >:(
Page created in 0.027 seconds with 21 queries.
