Author Topic: Cam Belt  (Read 2734 times)
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
Cam Belt
« on: 15 August 2014, 10:28:12 »
My car has 28K on the clock. Vx in Luton say a cambelt change is due (after 8 years or 80K) and offered to do it for the princely sum of £626 which I declined.
Your opinions please as to when a change is due/desirable and usual third party cost (ie. not Vx). Thanks.
« Last Edit: 15 August 2014, 10:40:34 by Lagondanet »
Re: Can Belt
« Reply #1 on: 15 August 2014, 10:40:06 »
It's due every 4 years or 40k (despite what your Vx dealer told you) and you should be able to get it done for under £300 by one of the forum indies, including parts.
On the interval I believe received wisdom is that the original interval was 4/40, Vx increased it to 8/80 and then dropped it back to 4/40 after having to pay out a bunch of warranty claims.. not all dealers seem to have got the memo.
Varche
  • middle of Andalucia
    • Golf Estate
Re: Can Belt
« Reply #2 on: 15 August 2014, 10:42:13 »
The wisdom of the forum is every 4 years OR 40k miles. Whichever comes first.
After that you are on borrowed time. The belts deteriorate with time.
There are experts on the forum who do cambelts and time the engine properly. Might be worth looking for someone nearby. It is also fairly easy to do yourself with the OFF video and the appropriate tools (locking kit and a large spanner for the crank.)i
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Cam Belt
« Reply #3 on: 15 August 2014, 10:47:52 »
Thanks for replies.
Well, car is 2002 (don't think it has been done before) mileage 28K. Should I get it done now or wait to 40K?
Varche
    • Golf Estate
Re: Cam Belt
« Reply #4 on: 15 August 2014, 11:00:18 »
Is it over four years? :o
Re: Cam Belt
« Reply #5 on: 15 August 2014, 11:12:12 »
JamesV6CDX is your man!  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Cam Belt
« Reply #6 on: 15 August 2014, 11:15:58 »
Thanks for replies.
So what your saying is cambelt has not been replaced in the last 12 years, needs doing asap, the last thing you want is to end up with is a broken 28k old engine.  ;)
Re: Cam Belt
« Reply #7 on: 15 August 2014, 11:27:17 »
Thanks for replies.
 :o :o :o :o :o
As suggested, it needs to be done every 4 years, regardless of miles done!
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Cam Belt
« Reply #8 on: 15 August 2014, 11:30:43 »
Noted. Thanks gents.
Re: Cam Belt
« Reply #9 on: 15 August 2014, 11:31:32 »
Typical price would be around 100 notes or so for the bits plus fitting which is about 1.5 hours.
Re: Can Belt
« Reply #10 on: 15 August 2014, 14:28:08 »
[quote author=aaronjb link=topic=125532.msg1600659#msg1600659 date=1408095606]
[/quote]
I paid £330 at my Vauxhall dealer. This included a new GM water pump. :y
They later said 'they had done their sums wrong'........ ;D ;D ;D
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: Cam Belt
« Reply #11 on: 15 August 2014, 14:34:01 »
Drop serek a line. His workshop isn't far from you.
PM with your requests.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Cam Belt
« Reply #12 on: 15 August 2014, 21:58:59 »
Second the above. About 45min drive to Huntingdon from Luton. :y
Hoof'land storeman.
Re: Can Belt
« Reply #13 on: 15 August 2014, 22:09:59 »
Not just the "wisdom of the forum", the 40K/4 years is as now specified by Vauxhall - although not all their dealers think so ::)
Not usually the belts that go - its the bearings in the tensioner and/or idlers ;)
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Cam Belt
« Reply #14 on: 22 August 2014, 21:47:11 »
Sorted! Top man. Thank you Serek for doing it so promptly & enthusiastically!  :y
Page created in 0.019 seconds with 15 queries.
