Lost Computer Data.
Started by Field Marshal Dr. Opti, 16 August 2014, 12:54:58
It simply vanished from the screen. Gone..........I suspect aliens. :-\
My Word .rtf document is just a blank page.
I have so far run a search on the computer for .asd , .wbk , .doc , and ~ files all to no avail. Does anyone have a way other than those already mentioned to retrieve a lost .rtf file?
Any help would be most welcome, chaps. :y
zirk
Rich Text Format, why you saving files in this format?, not that it matters if it gone, have you tried *(DOT)rtf or 'name of file(DOT)* in search, or recent Documents etc
davieboy0312
I got a program called "recover my files" finds anything lost even deleted. Works for me :y
Jusme
Most files that appear to be lost actually still exist; only the pathway to their locations on the hard drive have been lost.  :-\
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
Rog
Have you lost the actual file, or what was in it ?
Just a thought, but if you have opened the file with the correct file name, but it looks blank, is the typeface colour white and therefore cannot be seen ? If so use Ctrl + A to select everything and then change the font colour.
Above is a bit of a long shot, probably not the problem as Dr Opti is a "Doctor" and therefore far too clever to do silly things  ;D
was the auto - save feature enabled ?
Quote from: Jusme on 16 August 2014, 17:31:17
I'm guessing its an ntfs filesystem, and a small file (thus stored with filename in the mft). You may be lucky and the mft hasn't overwritten, but I wouldn't hold out hope
