Author Topic: fuel gadge  (Read 1086 times)
badmuver
fuel gadge
« on: 17 August 2014, 11:29:58 »
Hello all, I keep getting rang f miles on the display with a full tank .
flyer 0712
Re: fuel gadge
« Reply #1 on: 17 August 2014, 11:34:22 »
thought it will give you the range whether full or half empty ..or have I miss understood your question   ::)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: fuel gadge
« Reply #2 on: 17 August 2014, 11:39:56 »
Range display should always give a number of miles, when low it flashes irritatingly. Is your question about the fuel guage or the computer range display?
badmuver
Re: fuel gadge
« Reply #3 on: 17 August 2014, 11:42:21 »
When driving the display will change to range F miles and the needle will got to enough and the light will flash
terry paget
    • 3 Astras 2 Vectra
Re: fuel gadge
« Reply #4 on: 17 August 2014, 12:23:13 »
Sounds like fuel gauge sender unit failing. It's in the fuel tank alongside the pump. Access through panel in boot floor. Saloons and estates differ. Probably a guide in the maintenance guides section.
badmuver
Re: fuel gadge
« Reply #5 on: 17 August 2014, 14:08:55 »
Ok cheers for that info  :y
