Author Topic: Pug 206 - ABS sensor airgap spec.  (Read 1591 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 19 August 2014, 20:23:15 »
Anyone got a scooby doo on the above? Not even sure this is measurable as i think the tone ring is built in to the bearing/hub assembly?
If not i'll be pulling them out (assuming they're compliant  ::)) and cleaning any rust.
Cheers  :y
RIP Paul Lovejoy
Re: Pug 206 - ABS sensor airgap spec.
« Reply #1 on: 19 August 2014, 20:29:20 »
0.5mm
Webby the Bear
  • Northampton
« Reply #2 on: 19 August 2014, 20:31:10 »
0.5mm
You da man. Cheers Roberto Di Mascherano.
Any idea if there is access to measure? I take it there is if there's a spec but it is a Peu-git  ::)
RIP Paul Lovejoy
« Reply #3 on: 19 August 2014, 20:39:07 »
Yep
Webby the Bear
  • Northampton
« Reply #4 on: 19 August 2014, 20:57:58 »
Yep
RIP Paul Lovejoy
