Author Topic: tyre type thread.  (Read 3663 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
tyre type thread.
« on: 23 August 2014, 19:46:18 »
well I thought these would last me till october, but got a slight vibration,had a check and found  :'(
[/img]
[/img]
might need tracking doing at kwik fit.
Hoof'land storeman.
chrisgixer
Re: tyre type thread.
« Reply #1 on: 23 August 2014, 19:48:45 »
Bah, they'll be fine. Anything black and round will do :y
« Reply #2 on: 23 August 2014, 19:50:15 »
Not sure about the silvery highlights though... ;D
biggriffin
« Reply #3 on: 23 August 2014, 20:00:58 »
might have to go and get the angle dangles checked,then buy something for £100 pair again. :y
Hoof'land storeman.
chrisgixer
« Reply #4 on: 23 August 2014, 20:09:37 »
Chalk and a bit of string mate, no need for all that laser bollards.
4x4
« Reply #5 on: 23 August 2014, 20:12:11 »
What type of chalk and string do you recommend gixer  ;D ;D
« Reply #6 on: 23 August 2014, 20:13:02 »
Crayola and garden twine :y
chrisgixer
« Reply #7 on: 23 August 2014, 20:14:39 »
White obviously. Both of them. ;D
biggriffin
« Reply #8 on: 23 August 2014, 20:34:13 »
never more truth spoken than in jest. :y
you forgot the equal length 1ft and 1 1/2 dia poles.
« Last Edit: 23 August 2014, 20:36:15 by biggriffin »
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 23 August 2014, 20:45:08 »
Nah, use a rod sliding in a bit of tube between the front  tyres. Use it on front and rear edges. No measuring needed; at least for parallel.
« Reply #10 on: 23 August 2014, 21:36:05 »
How much you want for the tyres ? Ill turn them around and wear the other edge   ;D
chrisgixer
« Reply #11 on: 23 August 2014, 22:02:40 »
....what's wrong with the mark 1 eye ball? Hmm?
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #12 on: 24 August 2014, 00:01:19 »
Plenty of life left in them, keep going until the blow out wear indicator warning goes off. :o :o :o :o :o :o ;D ;D ;D ;D
  • Chatham, Kent
« Reply #13 on: 24 August 2014, 17:05:32 »
Because you spend more  time explaining to passers-by why you're lying on the ground, 2m in front of the car squinting at it. Some, er, equipment saves a lot of stupid questions.
chrisgixer
« Reply #14 on: 24 August 2014, 17:07:51 »
Nah, you need to think aloud while your working. They can't get a word in edgeways then. Saves a fortune on unnecessary equipment too. ;)
