Author Topic: Constant Low o2 Sensor Voltage. Omega 2.2  (Read 1396 times)
MeegaRob
  • London
    • 02 2.2
« on: 01 September 2014, 22:16:54 »
Hi All,
I've had a niggling feeling for a while that my fuel economy isn't quite what it should be. Not bad, but then again not good.
E.G. I'm getting low to mid 30s on a motorway run ( 2.2 Petrol auto ).
I think I see the reason here
As you can see the o2 sensor voltage is consistently too low. It should vary around the 0.45V rather then 0.1.
The data was taken using the logging facility on torque pro ( android ) for a short journey on a duel carriageway.
There are no ECU faults stored or pending.
Great I think. I'm running lean, just need to find that pesky vacuum leak, and it will all be sorted.
My problem is, I just can't find any leaks.
I've tried butane and carb cleaner, and even water to isolate the leak.
I swapped over the o2 sensor with a known working one from another car - Just in case. There was no change.
Here is my long term fuel trim.
So where do I look now? Is there a common place the vacuum system leaks? Or perhaps something else.
Thanks
Rob
steve6367
Re: Constant Low o2 Sensor Voltage. Omega 2.2
« Reply #1 on: 01 September 2014, 22:22:04 »
Hello and welcome  :y
If it helps my 2.2 does around 33mpg on a motorway run so sounds like your doing ok. Or are you saying your MPG has dropped?
Steve
MeegaRob
  • London
    • 02 2.2
« Reply #2 on: 01 September 2014, 23:05:12 »
Hi Steve,
The MPG has been bad for a while.
I have two 2.2 omegi, which makes for a good reference, and means it's a doddle to swap over parts.
I've only just learnt how to use the obd logging on torque pro.  So was interested to see that the good/blue 2002 omega has on o2 voltage oscillating around the 0.45V where as the bad/gold 2001 one oscillates around 0.1V.
I consistently get 42MPG on a motorway run from the blue one, but only 32-35MPG from the gold one.
Around town is difficult to quantify, but the gold one is less economical.
I know the stated MPG from the computer isn't a great guide, and I haven't done a brim to brim comparison, as it will cost a fortune to fill both tanks. Perhaps the logging info shows a problem though?
Thanks
Rob
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 01 September 2014, 23:15:20 »
I could get low to high 30 mpg on a 3.0 Auto on a run. If you swap Lambdas over to the other side, just to confirm its ok and the heater is working. No leaks, my next step would be Maf.
MeegaRob
  • London
    • 02 2.2
« Reply #4 on: 02 September 2014, 10:50:35 »
Hi Zirk,
Good suggestion, thanks.
I swapped over the MAF this morning, along with the ducting between the air filter and throttle body.
No change. The car still runs nicely with plenty of power, but the o2 voltage remains low.
Rob
« Reply #5 on: 02 September 2014, 11:20:42 »
Whats the coolant temperature sensor saying?
MeegaRob
  • London
    • 02 2.2
« Reply #6 on: 02 September 2014, 12:16:52 »
Hi Mark,
The ECU reports 85C, which is the same as the dashboard gauge.
Rob
