Author Topic: LPG Questions  (Read 3319 times)
    • 530D M Sport, 330i Coupe
LPG Questions
« on: 04 September 2014, 13:19:40 »
Quick questions for those with LPG installs.
I'm planning to install the vapouriser on the O/S inner wing where the aux pump used to reside (I believe this is where most have put it), I haven't got the kit as yet but wondered how this is fixed? Can you utilise the studs that are present on the inner wing?
Running the power feed to the ECU (planning to mount it where the self leveling pump currently resides) whats the best route for those wires? I'm a little concerned that running them around the slam panel area will cause them to go brittle over time with the heat from the radiator and condensor.
Diag connection - has anyone extended the lead and run it into the cabin fuseboard area? Just want to keep it tidy?
Injector loom - presumably the neatest way to do this is too graft the two looms together removing the piggy back connectors and original loom injector connectors and soldering them together.
TIA
« Last Edit: 04 September 2014, 13:22:26 by VXL V6 »
Re: LPG Questions
« Reply #1 on: 04 September 2014, 13:32:56 »
They generally have a single bolt fixing which is fitted through from the wheel arch...
No reason why you couldn't fabricate a bracket to fit the existing mountings, but be careful not to get too close o the engine as it's about exhaust manifold level and the engine does move :y
Bolting to the wheel arch directly does ensure that the vaporiser is as far from the exhaust as possible  :y
chrisgixer
Re: LPG Questions
« Reply #2 on: 04 September 2014, 14:17:21 »
On my first install I used one if those spare studs, it failed inspection. A no no as they aren't solid enough, which made sense tbh. Drill a hole, weather proof it, bolt it up, spray with under seal from the wheel arch side.
Running the diag port I a good idea and one I've considered but not implemented. It would help greatly if your having set up issues. Although might be a waste of time if all goes well.
Loom I ran in front if the the rubber fans (?) seal directly behind the slam panel. It's forward of heat flow although does get some residual heat from the metal work. There isn't enough slack to run it in front if the rad iirc plus there's the concern over accidental damage. Loom plug can pass through the holes in the body under the air box without issue.
Injector loom, one for the electrical experts. I never bothered as the time taken to connect up the loom is equal (or longer ? ) to that taken to install it without. Although being more electrically qualified it's probably going to swing it back in favour. :y
Re: LPG Questions
« Reply #3 on: 04 September 2014, 14:18:55 »
I didn't. The vapourisers generally have a threaded hole or two on the back and I just added an extra hole in the wing to bolt it up. You can also use a bracket, but unless you fabricate something yourself I'd say that mounting clearance is limited enough that it's unlikely that you'll be able to re-use an existing stud.
Mine runs across the front of the radiator under the slam panel and has caused no issues.
Not tried this but it should be feasible. It's only RS232 so it should cope with a wire of that length OK.
Yep, get another pair of the multiway connectors that connect the injector loom to the main loom and wire these to the LPG ECU, then you can just plug and play.
Re: LPG Questions
« Reply #4 on: 04 September 2014, 16:10:32 »
Eh?
How does a welded stud mounted on the structural inner wing not meet the requirements when compared to a cheap tat Chinese nut n bolt?
Weird
Re: LPG Questions
« Reply #5 on: 04 September 2014, 17:22:22 »
Eh?
Weird
This is UKLPG we're talking about. Common sense not required here.  ;)
chrisgixer
Re: LPG Questions
« Reply #6 on: 04 September 2014, 18:56:07 »
Eh?
Weird
No, I don't agree, think it through chaps. The vap has to be solidly mounted. Those are the rules.
So how do you mount a vapourisor on a single stationary welded in stud? Spin it on? The thread is too small so you use a bracket that involves using two or more studs.  So unless your using 8mm flat bar it will flap about,  and add leverage with all the pipes hanging off it to those studs.
I wasn't happy with the original mounting point and the tester pointed it out. I have to say, while I agree with Kevs view on the uklpg generally, I agreed with the tester fully on most of his observations, including this one, it has to be said.
Look at the weight of the original items that are heald by those studs. Although some are unused, they are not designed to take that amount of weight.
The studs are too far back anyway. It makes adjusting the vap pressure tricky against a hot exhaust manifold. And for Andy, the engine needs to up to temp to set it up correctly. ;)
Re: LPG Questions
« Reply #7 on: 04 September 2014, 20:18:31 »
VXL V6 - if you're passing, you're more than welcome to poke about under my bonnet...  ...or if not in a hurry, I could swing past some time :)
Re: LPG Questions
« Reply #8 on: 04 September 2014, 23:01:55 »
Cheers TB
I don't think I'm likely to get started on the LPG until the Christmas break. Unfortunately 3 MOTs a tax disc and jobs to do before the MOTs sees my budget spent for the next couple of months.
I thought I might try and get hold of the front end stuff in December and start mounting bits and bobs slowly.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: LPG Questions
« Reply #9 on: 05 September 2014, 19:02:52 »
I took some pictures of my install for B4ndit a few weeks back.
If you pm me a email address, i'll send them to you
Re: LPG Questions
« Reply #10 on: 05 September 2014, 19:06:18 »
Cheers, on it's way  :y
chrisgixer
Re: LPG Questions
« Reply #11 on: 05 September 2014, 19:35:41 »
When fitting the vap, do so with the Allen key fitted in the adjuster nut, IMO, so you can see how much access is available, and what will burn your hand, or hopefully not. ;)
Re: LPG Questions
« Reply #12 on: 05 September 2014, 20:54:30 »
Okey Dokey....
I'll have loads of questions soon I'm sure!
Re: LPG Questions
« Reply #13 on: 05 September 2014, 20:59:24 »
In fact, next question - Is the grommet that allows you to feed the wires into the cabin for the gauge and buzzer the one that sits just behind the brake servo?
chrisgixer
Re: LPG Questions
« Reply #14 on: 05 September 2014, 21:01:15 »
Yep.
Page created in 0.035 seconds with 16 queries.
