Author Topic: Autel ABS / SRS code reader.... already paid for itself  (Read 3067 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 05 September 2014, 15:35:27 »
Afternoon gents,
Got my new code reader (after the incorrect one was delivered...my fault  ::)). Used it a moment ago on the wife's 206. Read codes as front right and left ABS sensor coherence. I'd already fixed the fault last week by correctly gapping the sensors and wire brushing the immense crud that had built up so erased the codes...... fault(s) gone!  :y
And it read that I've got p1801 and p1802 airbag faults.
So, all in all, excellent so far :)
RIP Paul Lovejoy
Re: Autel ABS / SRS code reader.... already paid for itself
« Reply #1 on: 05 September 2014, 15:41:37 »
Very good  :y.
So which one did you eventually buy?  :-\
Webby the Bear
  • Northampton
« Reply #2 on: 05 September 2014, 15:46:32 »
Very good  :y.
I initially purchased the Autel MD702. This however only reads about ten different types of cars... not including Peugeot  ::) My mistake though for not reading the description properly.
SO. Now have the Autel MD802 which reads everything........ even Bugatti  :o :y
RIP Paul Lovejoy
« Reply #3 on: 05 September 2014, 15:49:33 »
I think we need to change your name to SpendyBear! ;D
Webby the Bear
  • Northampton
« Reply #4 on: 05 September 2014, 15:55:45 »
Lol well, as stated a little while back I was left some money so I wanted to spend it on getting a career set up..... would prefer to have my granny back  :'(
RIP Paul Lovejoy
« Reply #5 on: 05 September 2014, 15:57:23 »
Aaaand now I feel bad.. Sorry Webby!
Webby the Bear
  • Northampton
« Reply #6 on: 05 September 2014, 16:01:54 »
Sorry mate, wasn't meant to make you feel bad. I just wanted to spend the money she gave me on things that could get me going ya know  :) :) :) :)
RIP Paul Lovejoy
« Reply #7 on: 05 September 2014, 16:09:27 »
Very good  :y.
SO. Now have the Autel MD802 which reads everything........ even Bugatt:o :y
Mine is an Autel Maxiscan MS509. The Corsa loves it.  :y
....but it won't work on the mighty 2.6. :'(
« Reply #8 on: 05 September 2014, 16:12:41 »
Very good  :y.
How much, Mr Bear?
Webby the Bear
  • Northampton
« Reply #9 on: 05 September 2014, 16:13:54 »
It was £190.
Expensive, but it'll be in my armoury forever or until I break it  ::) :y
RIP Paul Lovejoy
« Reply #10 on: 05 September 2014, 16:19:19 »
It was £190.
But if it does all it should then it could be a wise investment. :y
« Reply #11 on: 05 September 2014, 17:16:22 »
Very good  :y.
Which is weird, because my MS509 works with my 3.2..
[edit] Although only when the engine is running, which is weird.
« Reply #12 on: 05 September 2014, 18:56:05 »
Very good  :y.
Ignition on........Ignition off.........engine running...engine off......It won't play ball. :-\
Webby the Bear
  • Northampton
« Reply #13 on: 06 September 2014, 20:14:54 »
Been thinking (dangerous I know :))
Why would an airbag code be 'P' for powertrain? Woulda thought it'd been b for body or c for chassis  :-\
RIP Paul Lovejoy
