Author Topic: mot advisory  (Read 3980 times)
darrenfos
  • eastleigh
    • omega elite manual
mot advisory
« on: 08 September 2014, 18:33:20 »
Hi all, car passed mot but had advisory note, both front suspension arm rubber bush deteriorated but not excessive movemet, + rear subframe rubber bush wear but not excessive movement are the fronts easy to do and whats involved, cheers darren
omega is like marmite you know the rest
Re: mot advisory
« Reply #1 on: 08 September 2014, 19:32:06 »
Undo the front bolt, lever the arms down and remove the old bush. Then replace with poly bush. Refit bolt and jobs done :y
If you remove the arm you will need the geometry resetting... ignore at your expense :y
darrenfos
  • eastleigh
Re: mot advisory
« Reply #2 on: 08 September 2014, 19:44:16 »
Just to make sure its the bush at the very front (close to bumper)of the wishbone
Re: mot advisory
« Reply #3 on: 08 September 2014, 19:58:02 »
:y there's a guide hereaboots for replacing it with poly without removing the arms...
Re: mot advisory
« Reply #4 on: 08 September 2014, 21:39:24 »
I let the garage change my rear dohnuts  ::) Let them have the privileged of changing them  :-[
darrenfos
  • eastleigh
Re: mot advisory
« Reply #5 on: 09 September 2014, 19:09:30 »
Is the front suspension arm's easy to change as the parts chap said it was easier than changing the bush?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: mot advisory
« Reply #6 on: 09 September 2014, 19:14:22 »
But you will still be changing the bush in 18months time so just fit poly and forget them.
Jaguar XJ6
darrenfos
  • eastleigh
Re: mot advisory
« Reply #7 on: 09 September 2014, 19:22:05 »
Car only done just over 300 miles between mot's done under 2000 miles in 4 years, and is not everyday car so not fussed about polybush.
YZ250
  • Online Online
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: mot advisory
« Reply #8 on: 09 September 2014, 19:40:51 »
Really depends how good you are with spanners. I personally find it quite straightforward but others may think it's an awkward job.  :-\  I also have a press to change the rear bush myself so that helps as well.  :y
Lining up the rear bolt is the only fiddly bit.  :y
Fitting poly is not only for longevity, it makes it possible to change the front bush with the wishbone still fitted to the car.  :y
darrenfos
  • eastleigh
Re: mot advisory
« Reply #9 on: 09 September 2014, 19:48:05 »
How do you get the old one out as for the other question i am ok with most jobs i do the service myself, brakes, sensors, cam covers done the drop links few months back i would need a puller for the rear.
YZ250
  • Online Online
Re: mot advisory
« Reply #10 on: 09 September 2014, 19:55:29 »
You'd be fine then.   :y
As Al said, there's a step by step guide on here somewhere.   :y
Re: mot advisory
« Reply #11 on: 09 September 2014, 20:05:05 »
Here do...
How to remove wishbone front bushes :y
It does say remove from car but ignore that bit... principle is the same :y
There is/was a video how to for fitting the poly bush without removing the wishbone... try youtube :-\
« Last Edit: 09 September 2014, 20:06:57 by Doesn't play well with others... »
darrenfos
  • eastleigh
Re: mot advisory
« Reply #12 on: 29 September 2014, 19:00:23 »
Done fronts put new wishbones in now for rear donut bush can you remove the plate with the car on the ground or does it need to be jacked. Cheers
darrenfos
  • eastleigh
Re: mot advisory
« Reply #13 on: 29 September 2014, 20:07:35 »
Can u jack rear up place a building block under wheel and remove jack or does the wheel have to hang to replace donut bush. Just a idea
Re: mot advisory
« Reply #14 on: 29 September 2014, 20:19:49 »
Do it on the ground :y
If the car is lowered, then up on a curb is sufficient, or ramps :y
Should add, the levering required is not summat that you want to do on a jack of any description...
