W reg vw passat. This is turbo issue right?
Started by Webby the Bear, 08 September 2014, 18:55:02
Webby the Bear
Ok boys thanks for your input. i was only going on what the wifes dad said.
ill get him to find the engine code :)
RIP Paul Lovejoy
Webby the Bear
Ps, ill get code reader on it.
been researching. assuming its the 1.9 non-v6 (im sure its not v6). seems like maf is common issue and also n75 valve....  is this the vw term for wastegate? lol
as said will get the engine code asap but thought id ponder. out loud :)
RIP Paul Lovejoy
Don't guess, diagnose..... :y
Also, as said, it might not have a wastegate  :D
An N75 is the boost pressure regulator valve
Webby the Bear
Quote from: Marks DTM Calib on 09 September 2014, 13:30:26
Completely agree mate. though ive never worked on a VW diesel so i was just really pondering out loud to try and get things right in my head. sort of like planning a provisional attack that i can amend ;)
speaking away from this issie itself, why are there so many vac lines?? i thought it was very simple..... exhaust gas spins turbine. this in turn spins compressor. compressed air goes back in to the inlet. and a wastegate (or equivalent) was there to stop over boosting when the turbo ran too fast. i really thought it was that simple  :-[
but as said, ive never dealt with one in real life (hence the pondering lol) so im really keen to get stuck in to this.
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 09 September 2014, 13:44:32
Variable vane turbo if its a Pd engine and no wastegate :y
other rides
Webby the Bear
Isnt PD the really advanced diesel system?
im assuming the one on her dads 2000 passat will be DI with an injector pump?
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 09 September 2014, 14:02:18
2000 is right on the change,could be either :y
other rides
1999 was when the first PD's hit shores.
And advanced....er no, it was a compromise setup as VW don't like paying royalties to Bosch for Common Rail.  ;D :D
As for VW or any other, they all work the same!
The vac pipes will do many things for the likes of swirl flaps (if fitted - multivalve engines only), possibly EGR (is vac operated) and in this case, although not vac operated, the inlet pressure can control the boost (or on the variable vane setups, vac controls the vane position)
Webby the Bear
Cheers boys :)
Will update when i get this engine code :)
RIP Paul Lovejoy
The Sheriff
Quote from: Marks DTM Calib on 09 September 2014, 14:46:05
Never mind the turbo, Bet his fickin head's spinning now.  ;D
Webby the Bear
Quote from: STMO on 09 September 2014, 15:14:15
Yup lol
RIP Paul Lovejoy
4x4
Best thing to do is actually see the car,and take it from there,it may well be something simple and easy to fix :y
Webby the Bear
Quote from: 4x4 on 09 September 2014, 15:28:49
Completely agree mate. He still aint told me engine code. going to chase up now.
RIP Paul Lovejoy
Webby the Bear
Reset then boys. Here's the pics of hopefully engine code. Is this the 1.9 tdi as suspected?
RIP Paul Lovejoy
serek
#29
No engine code there
On timing belt cover should be label with code or in boot under carpet
