Author Topic: Locking Wheel Nut removal  (Read 3897 times)
Re: Locking Wheel Nut removal
« Reply #15 on: 22 June 2008, 10:46:59 »
Aye, its all in the wheel, so cant get anything like that on  :(
Tempted to ring round scrappys / tyre bays / rac and see what they say
Bugger, sounds like drilling may be option.
Of course, after the wheel was last fitted, didn't you go round and retorque the wheelnuts?
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #16 on: 22 June 2008, 11:13:11 »
had a similar problem (i think) before, what i did was to drill into the remains of nut and then use a centre punch or similar drift and hammered it round to start it off ::)
might work :y
« Reply #17 on: 23 June 2008, 12:00:33 »
Well a 3/4 socket hammers on nicely, just doesnt grip quite enough, so looks like a 3/4 remover may do the trick.
« Reply #18 on: 23 June 2008, 12:09:07 »
I have a set of those removers and generally have found them crap.....that maybe because I explore all other techniques first before trying them though!
« Reply #19 on: 23 June 2008, 12:09:56 »
any chance of bunging em in the car at the weekend?
Ill post em back to you
« Reply #20 on: 23 June 2008, 12:10:49 »
Yep, no problem  :y
« Reply #21 on: 23 June 2008, 12:11:06 »
Cheers
I'll try anything!
Need some more drill bits as well ;)
Tried araldyting the key to the lock overnight, didnt have enough grip to survive the bar though :(
« Last Edit: 23 June 2008, 12:11:24 by jimbob »
sassanach
  • trowbridge
« Reply #22 on: 23 June 2008, 13:09:02 »
in situations like this i get the largest nut i can get on top of the wheel stud,crank up the mig welder and weld the centre of the nut to the remains of the wheel stud.allow to cool and if you can weld ::)the stud should wind out. 8-)
« Reply #23 on: 23 June 2008, 14:52:53 »
A great plan with just 3 small drawbacks
1. I cant weld
2. I havent a welder
3. I cant weld
« Reply #24 on: 23 June 2008, 15:02:50 »
1. I cant weld
3. I cant weld
Could bring a welder to the lakes.... Time to see what their electrical hookups are made of?  ;D
Growler
« Reply #25 on: 23 June 2008, 15:19:15 »
You could drill small holes into the nut from front on and then split with a chisel
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
« Reply #26 on: 23 June 2008, 16:55:41 »
I used to have locking wheel nuts, but they weren't very good.  They gradually distorted and it became more and more difficult to get them to engage properly.  Eventually, after failing completely to remove a wheel, I get the got the garage to take them off.
Nobody's nicked my wheels yet. :)
Which is rather disappointing - I think they're really ugly. :(
« Reply #27 on: 23 June 2008, 17:28:06 »
1. I cant weld
3. I cant weld
Cheers, not bringing that car up though.  :y
« Reply #28 on: 23 June 2008, 17:36:06 »
1. I cant weld
3. I cant weld
LoL, Send Ljay on a course
CV will soon read
Mavelous Mother
Domestic Godess
Miggy Mechanic
and
Marvelous Mig Welder
Hope I got them right, sure it can be ammended if incorrect.    PMSL
PS  I left off the acrobatics bit ;D ;D ;D
« Last Edit: 23 June 2008, 17:46:23 by skruntie »
johnnycboy
  • Colchester
« Reply #29 on: 23 June 2008, 19:18:20 »
I spent about four hours drilling and chiselling the basteward wheel nut on the rear ns passenger wheel.  It does work but make sure you have plenty of drill bits - they seem to have a tendancy to break off in the nut itself.  Its more persevarence than anything else.  If you have an SDS drill with hammer action and chisel, give that a go, worked for me. :exclamation
