Author Topic: pipes  (Read 1860 times)
badmuver
pipes
« on: 22 September 2014, 16:22:44 »
Hello, I need a bit off help to identify two breather pipes  as in the pic, as they have split and have no part number on them  :(
https://www.dropbox.com/s/eig5nw7aqgkn06w/2014-09-22%2016.12.47.jpg?dl=0
Re: pipes
« Reply #1 on: 22 September 2014, 17:11:29 »
One on the right is the vent hose from crankcase part #90499659
Small one on the left is vent hose from inlet manifold part # 90528437
badmuver
Re: pipes
« Reply #2 on: 22 September 2014, 17:48:15 »
Thank you so much  :)
    • 530D M Sport, 330i Coupe
Re: pipes
« Reply #3 on: 22 September 2014, 18:13:03 »
There's a modification for the one on the right - involves cutting it in half and fitting a filter box which has a gauze in it.
Re: pipes
« Reply #4 on: 22 September 2014, 18:57:18 »
Is this a standard fit on later cars, if not is it advised and is there a part number for the filter :-\
4x4
Re: pipes
« Reply #5 on: 22 September 2014, 19:10:20 »
Cheaper to get that part from a scrappy if you really want to fit it
Re: pipes
« Reply #6 on: 22 September 2014, 19:15:01 »
It was generally fitted to cars that suffered with the base idle problem as part of a TIS notification. I have one somewhere so should be able to find you a part number. I believe a second hand one should be fine as you can clean the gauze quite easily.
Re: pipes
« Reply #7 on: 22 September 2014, 19:18:24 »
Ok so a low mileage 2003 car is unlikely to benefit from it then :-\
Re: pipes
« Reply #8 on: 22 September 2014, 19:26:33 »
Just like the V6's, regular oil changes and breather cleaning is the key. That crankcase breather pipe does crumble after a while regardless.
Which reminds me, I haven't cleaned the breathers on the 2.6 for over 21K  :-X Mind you it lives mainly on the motorway and has 3 - 4K oil changes (so one at least every month)....
Page created in 0.026 seconds with 17 queries.
