Author Topic: Check light.....is it possible to turn it off for good?  (Read 3866 times)
carswaps
  • West Yorkshire
    • Omega MV6 3.2 Estate
« on: 24 September 2014, 20:35:05 »
Is it possible maybe via software to turn of the check light and messages?
or maybe remove a wire/s?
I've got the low beam message and have seen all the fix's on here but wondered if it was possible to turn it off?
Re: Check light.....is it possible to turn it off for good?
« Reply #1 on: 24 September 2014, 20:44:59 »
At risk of being, er, controversial... you could always fix the fault ::)
carswaps
  • West Yorkshire
« Reply #2 on: 24 September 2014, 20:51:39 »
I will, just wondered if it was possible.
« Reply #3 on: 24 September 2014, 21:09:33 »
Yes. But its telling you that the headlight aiming isn't working, so handy to have.
You need a £4k diags machine to turn it off.
« Reply #4 on: 25 September 2014, 00:29:41 »
Probably cheaper to find and fix the fault  :) ;)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #5 on: 25 September 2014, 08:00:10 »
Or buy a new car :)
carswaps
  • West Yorkshire
« Reply #6 on: 25 September 2014, 09:15:41 »
I had the tyre pressure monitor turned off on my Audi RS6 with some software (can't remember what it was) but just wondered if the Vauxhall onboard software allowed this like this to be changed.
« Reply #7 on: 25 September 2014, 19:31:35 »
VAGCOM.
Nobody makes anything similar that works for GM.  Its technically possible to turn off this specific error with GM diags equipment. But its far cheaper to fix the fault.
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
« Reply #8 on: 25 September 2014, 20:46:56 »
why break that that's not in need of breaking ?
  • Auckland
    • Mazda MPV
« Reply #9 on: 25 September 2014, 23:16:49 »
VAGCOM.
I think they try to call it VCDS now (to get past the word filters perhaps? ::))
Temetsy
  • Finland
    • b1 x25xe sedan
« Reply #10 on: 26 September 2014, 08:58:06 »
So it's not possible to disable certain check control features like windshield washer fluid level and brake pad monitoring?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #11 on: 26 September 2014, 10:15:05 »
I would have thought you can unplug them and bridge the terminals with a paper clip....
My BP sensor is tied up and out the way.
RIP Paul Lovejoy
Temetsy
  • Finland
    • b1 x25xe sedan
« Reply #12 on: 26 September 2014, 16:07:15 »
The problem is that my washer fluid res. has no sensor or plug there ::) And that pad wire trick I do know but it would be nice to just program both of those off..
« Reply #13 on: 26 September 2014, 16:25:13 »
You could hard wire them out on the back of the MID/GID/CID
Webby the Bear
  • Northampton
« Reply #14 on: 26 September 2014, 20:47:18 »
Don't forget also that there is the coolant level sensor message to think about.
As someone on here mentioned (think it was AndyB...cheers mate ;)) if something catastrophic happens to the cooling system you might not realise until the temp. soars and you blow a HG. I'd keep it just for that. imo  :y
RIP Paul Lovejoy
