Author Topic: Don't the facelifts rust at all?  (Read 1986 times)
bedders
  • Brigg, Lincolnshire
« on: 23 June 2008, 20:23:57 »
Am I just lucky, or are the facelifts not prone to rust anywhere, apart from the odd stone chip?
I'd be interested to hear other members experience. :y
Bog standard MY 2000 3.0 Elite Manual Estate + LPG
Danny
  • Wigan, Greater Manchester
Re: Don't the facelifts rust at all?
« Reply #1 on: 23 June 2008, 20:28:00 »
yes they are, i think wheel arches are the first places to check on facelifts
estates are prone to it where the rear wiper is
« Reply #2 on: 23 June 2008, 20:28:41 »
the can, if neglected, must less rust than pre-facelifts.
Mine had 1 spot, passenger door, right at the bottom corner on the lip, only visiable with the door open. Its about 1/2 the size of a 5p coin.
Dads 2.2 has no rust...
SteveD
  • Blackpool (no casino)
« Reply #3 on: 23 June 2008, 20:29:11 »
Mines rusting fine thanks. >:(
Rear tailgate under the wiper cover, bottom of rear arches near the door. Apart from that it's fine!
SteveD
« Reply #4 on: 23 June 2008, 20:29:57 »
LMAO you just read my mind!
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
« Reply #5 on: 23 June 2008, 20:30:17 »
 :'( :'( :'( wish I had one! my pre facelift is getting quite bad now  :'( :'( Suppose I will have to spend a little soon !!
bedders
« Reply #6 on: 23 June 2008, 20:41:29 »
Well it says a lot for the model, if they are the only areas, I'm not complaining mind ;D
It means that the car really is a long ownership prospect.
mars
  • Cannock, Staffordshire
    • Vivaro Sportive BMW 330d
« Reply #7 on: 23 June 2008, 20:41:50 »
I must be lucky, 2001 has 73,000 on clock and no rust at all. :) :)
                        2003 has 61,000 on clock and no rust at all. :) :)
There is no such thing as bad beer, some beers are better than others.
Richie London
  • heathrow
« Reply #8 on: 23 June 2008, 20:42:46 »
same spot as mine
bedders
« Reply #9 on: 23 June 2008, 20:44:53 »
Exactly, mine is a 2000 with 85000 with no rust (at all) :)
    • 530D M Sport, 330i Coupe
« Reply #10 on: 23 June 2008, 21:20:00 »
They also rust on the tops of the doors the same as the prefacelift, all down to the clips holding the rubber trim on I believe.
Olympia5776
  • Ireland
« Reply #11 on: 23 June 2008, 21:49:36 »
Get a plastic plunger oil can with as small a tip on the end as possible. Fill with a mix of 85-15 of Waxoyl and white spirit. Spray the oil down around the plastic trim surrounding the rear wiper spindle until it slowly oozes out onto the paint. Repeat until the cavity is as full as you can get it.
On the estate ,open the two access panels on the rear aft of the wheel arches. Pull back the sound deadening and spray the mix at the top of each arch to panel join allowing the excess to slowly run down the cavity between the two .
Re the door tops , insert a narrow plastic wedge between door and rubber seal and lift enough to get the tip of the oil can in ( hence the reason for getting as small a tip as possible ). Slowly run the wedge followed by the gun slowly spraying waxoyl as you go until there is a good film between the two surfaces. It will be slightly rippled but will flatten out again in a couple of days as the mix creeps.I do this several times a year , it takes less than five minutes to do both areas and so far has prevented any rust appearing on my facelift.
All the areas I've seen Omegas rust can be prevented by simply cleaning the salt and grit off and simple maintenance.
I'm about to re waxoyl the inside of the door and tailgate bottoms .This time of year is best when the warm weather assists the mix to creep into all thos e immpossible to get to cavities.
"Clean it and keep it " :y
Don
Danny
« Reply #12 on: 23 June 2008, 22:31:43 »
i'm not one for spending hours polishing mine, but when its washed i give it a good drying, and pay attention to under the door areas and wheel arches
also when its rained
