Author Topic: V6 Power steering pump type info.  (Read 1577 times)
carswaps
  • West Yorkshire
    • Omega MV6 3.2 Estate
« on: 27 September 2014, 11:14:25 »
After buying a pre used power steering pump for my 2001 3.2 V6 and it turning out to be the wrong one, I thought I would share some info I found out after.
Many of you will already know this info but like me some may not and it will save you the hassle I went through.
if you have power steering problems before taking the pump off have a good look at the pump fittings.
Early Omega 3.2 V6 and 2.6 V6 were still using the old stock 2.5 V6 and 3.0 V6 power steering pumps.
The way to tell is:
Older type 2.5 V6 and 3.0 V6
Newer type 2.6 V6 and 3.2 V6
Physically the pumps both fit as the mounting holes are in the same place.
You could fit a new length of rubber pipe to the reservoir but the early threaded pipe and banjo fitting are different!
The threaded early pipe will actually screw into the later banjo thread but will leak due to the depth of the fitting!
If this helps one person from buying the wrong pump it was worth the effort  :y
(Maybe this could be added on to this thread?)
http://www.omegaowners.com/forum/index.php?topic=90607.msg1155511#msg1155511
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: V6 Power steering pump type info.
« Reply #1 on: 27 September 2014, 11:23:00 »
Good info that bud   :)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« Reply #2 on: 17 April 2015, 17:02:43 »
Do you know if this difference in pumps are related to the difference in cambelts.
I have a 2001 built late 2000 according to some date codes I've found on it. I have found a pump from a 2003 and suspect that it wouldn't fit on my 3.2L V6
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
driver115
  • caistor lincolnshire
    • 3.2MV6
« Reply #3 on: 18 April 2015, 07:13:40 »
thanks for this information, will shortly be dismantling one of my omegas and some of the parts I`ll be keeping for the other so will note and compare for differences :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 18 April 2015, 07:25:34 »
Clicky no workee
Hoof'land storeman.
