helped needed with prices of omegas.
Started by conalnugent, 29 September 2014, 09:26:27
conalnugent
Hi there. My trusty 2.5td has served me well but although id keep driving her for another few years ive gotten lucky and can afford a better one. Can someone help me with priced?
Want a 3.2 elite estate with gas conversion and low miles and must be super mint.
Price for. ...... less than 50k miles
Up to 70k miles.
Also with full history and receipts.
Big ask yes and I know the 3.2 estates with low miles are hard to find.
If I cant find a gas converted one,  how much would it cost to buy a 2nd hand kit or to pay someone to fit.
Thanks
Quote from: conalnugent on 29 September 2014, 09:26:27
Up to 70k miles.
Thanks
A really mint one could be £4k, but others as low as £900 (or less)!  It depends on so much, but personally pay as much as you can afford for the best available, remembering that such low mileage ones are becoming very rare and attracting higher prices. ;)
omegod
I wouldn't be that bothered with mileage to be hones as they are a tough unit and anything with LPG will have been converted for a reason,usually because a lot of mileage is being covered. I would be more inclined to buy something for a grand or so and go right through it with new cambelt, suspension,rocker gaskets, ATF change and a sump clean up. Just my opinion  ;)
conalnugent
Wow.  4k is quite a bit. Will be up on about 2.5-3k I'll want to spend.  Want a motor that I can drive for at least 5 years and doesn't need anything bodywork wise.
Quote from: conalnugent on 29 September 2014, 11:53:58
You're shit out of luck then ::)
Quote from: Doesn't play well with others... on 29 September 2014, 12:33:16
Ah, that's so cruel! :o :o ;D ;D ;D ;D ;D ;)
I did say that was the maximum for a minter. :D :D
£2k is enough for a mint one imo  8) There is plenty around  ;)
The Sheriff
I've done a search on the net. Omegas range from £15 for a poor example, right up to £120 for a decent one.
HTH.
Quote from: STMO on 29 September 2014, 18:05:31
HTH.
For an Omega with " less than 50k miles Up to 70k miles".?? :o ???
The Sheriff
Quote from: Lizzie Zoom on 29 September 2014, 18:07:52
HTH.
Yup. ;D
Quote from: STMO on 29 September 2014, 18:09:21
HTH.
Yup. ;D
Buy us one then Steve!  I'll go up to £120 for a 50K one. ;D ;D ;D ;D ;D ;D ;) ;)
Assuming you have the same hoops as we do, don't bother with 2nd hand LPG tanks, as they have to be rechecked after 10yrs (and its cheaper to replace the tank).
conalnugent
Quote from: TheBoy on 29 September 2014, 21:21:21
Whats it cost to get one put in?
zirk
Quote from: Lizzie Zoom on 29 September 2014, 09:34:59
Price for. ...... less than 50k miles, Up to 70k miles. Also with full history and receipts.
Blimey Lizzie. let me know where I can buy a 3.2 LPG Elite Estate with 50 to 70k on the clock for less than 900 notes, I might buy a couple.  :D
Quote from: zirk on 30 September 2014, 14:38:41
Steve reckons he can pick em up for £120! :o :o :o
I have asked him to get one, so add one for you to the list! ;D ;D ;D ;D ;)
No, I can expect that a low mileage one that has rust showing and is showing signs of age due to mistreatment could be available for a low price.  Don't forget though that even my minter is only worth £800 max on webuyanycar.com!! ::) ::) ::) :o :o :o ;D ;D ;D
