Author Topic: Steering box removal (LHD car)  (Read 7612 times)
kcl
  • Finland
    • Volvo V60 D4 -14
« on: 30 September 2014, 10:30:37 »
I know most of you have the steering on the wrong side but still I hope someone could help me. I'm removing the steering box to replace it. Have read through TIS which says to remove
- ECU/fuse box (done)
- ABS unit (no, not really, do I have to...)
- brake servo (which I do not believe)
- aircon pipes (which I'd like to avoid until it's imperative).
So far I have the box bolts off the frame, connection to steering wheel open, box is moving forward but still far, far away from coming off. Next step is to remove ABS unit. What I need to take care of? Does it have to be bled afterwards and is this "TECH2 only" -job? AC pipes I do not care, some gas will leak out but I won't be telling anyone... Any hints what to do, what parts are needed to come off and which parts are unnecessary to remove, although mentioned in TIS?
When I have the box out I will be replacing leaking AC compressor seals and possibly do the exhaust manifold gasket as I suspect it's leaking and I will now have room to do it. Anytjing else that should be done at hte same time?
chrisgixer
Re: Steering box removal (LHD car)
« Reply #1 on: 30 September 2014, 10:40:15 »
Sounds much more awkward than removing the box from a right hand drive car. Are you SURE yours is fitted on the correct side? ;) ;D
Abs bleeding is defo tech 2 job. Can it be moved aside with carefull pressure on the metal brake lines....?
I remember removing servo just to give room, and that the brake light switch broke on removal. Vey easy done as the tangs snap off. Best to have a spare if possible.
But all on a right hand drive obviously.
« Reply #2 on: 30 September 2014, 10:45:33 »
You should be able to ease the ABS unit up quite a bit with the pipes still attached thus avoiding having to bleed the setup after.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #3 on: 30 September 2014, 10:49:36 »
I have no yet even seen the brake light switch, where is it? By the pedal? No? On the ABS box?
If i disconnect the ABS box will it get air in it? E.g. when renewing brake lines you open connections and can replace the pipes without any issues, how will this change when ABS box is out? Of course it will be emptied but still, as long as the pump does not run I can not see air getting inside?
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #4 on: 30 September 2014, 10:53:20 »
Coming to think of it you are right, the pipes from master cylinder to ABS unit are flexible so I might be able to lift it enough...
Last night I thought it would be easier to lift the lump out first than to tackle the box out with engine in  >:(
chrisgixer
« Reply #5 on: 30 September 2014, 10:55:52 »
Switch is up behind the pedals. If removing servo, it has to be disconnected from the pedals which means disturbing the switch.
As Marks post, see if you can move the pump out the way WITHOUT removing brake lines from the pump. No need for tech2 then.
But if brake lines removed ther WILL be air in the system. If air is pre abs pump it will need bleeding.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #6 on: 30 September 2014, 11:30:20 »
Thanks. I will not be taking the servo out. No. Unless I have to... No, I dont have to... Hope so.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #7 on: 06 October 2014, 08:53:23 »
Ok, got the job done. Not according to TIS. No photos, thought they'd not help you because you have the gubbins on the other side, but this is generally what I did:
- Fuse box and ECU out-->would not have had to but I did because TIS told so and at that point I thought it is best to follow TIS
- PAS reservoir out
- steering axle bolts off from cabin side
- ABS unit heat shield off to get to the screw holding the unit
- ABS unit screw off (this did not help much/at all)
- Steering box bolts from chassis off
- at this point I tried, and tried, and tried but the thing would not fit to come out
- left hand downpipe off
- left hand exhaust manifold off (dead easy, most difficult part was to get heat shield out. all screws and nuts came off very easily)
- at this point it looked like progress. I've got a block heater installed and it is partly on the way but decided not to take it out because I don't have the seals to re-seal it and did not want to get coolant out (it pour litres from the block when opened...)
- oil filter was the last obstacle, removal of the lid only did the job. After that the box came out.
I also think I have finally found the cause of my "sometimes stiff steering"; as some may remember I had this blind spot only when cold etc. Top bearing of the main shaft, just below the lid where the adjustment screw is, is very badly worn. Why, I have no idea, but the bearing is very, very worn. It rattles when rotating it with fingers. All balls inside box were ok, main screw looks intact, other bearings are fine, PAS side of the box looks ok, all oil vains are clear etc. So, I might salvage this by putting in a new bearing but then I do not have any idea how to adjust the basic play in the box so I will be putting in a second hand unit.
chrisgixer
« Reply #8 on: 06 October 2014, 14:00:15 »
Adjusting the box is easy if you've just done all that lot.
But MUST be done with steering box and column aligned together correctly, and dead ahead. Or it will go horribly wrong. But if aligned then the tightest point of adjustment can be felt on the torx screw with wheels off the floor while moving the steering.
At that point, back it of a tiiiiiiiny fraction and do up the lock nut. Seemples.
chrisgixer
« Reply #9 on: 06 October 2014, 14:03:36 »
Ps. There is a mark on the box input shaft to help alignment with the column/the flat face either side if the column/and the flexi joint that connects them both.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #10 on: 07 October 2014, 06:30:06 »
Thanks. But still I think I'll end up with better result putting a second hand unit in rather than trying to repair the old one. Seems that also the other needle bearing is done, the one deeper inside. I only wonder why. Only less than 200 000 km on the clock when the symptoms started  :-\ Could this be due wrong PAS fluid? Someone has used DEX3 in the past?
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #11 on: 10 October 2014, 05:31:20 »
Looking to buy a 2nd hand box to replace the worn one. Are they all the same on V6 cars, facelift/ prefacelift?
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #12 on: 10 October 2014, 09:56:10 »
Ok, I had asked this alo in the past and the assumption was that they're all the same if fitted with servotronic
« Reply #13 on: 10 October 2014, 20:13:32 »
I would have thought any '98+ v6 box would be fine :-\
Lhd obviously...
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #14 on: 11 October 2014, 18:02:49 »
Lhd obviously...
That's what I think also. Any with electrical connector and from V6 will do?
SOmeone with EPC could check what difference is between 9 227 769 and 9 227 771? Google said that first part is for without variable assist, latter being for variable assist; both ones have the solenoid on them?
