Author Topic: Discvoery 1 v8 project  (Read 1994 times)
Crazycarzowner
« on: 01 October 2014, 19:48:51 »
Well, not done anything really to the Disco since I bought it in July. So today I had a looky see at what work requires doing to it AND what  I  want to do to it.
So,
New brake discs & pads all round
New Shocks & springs
Poly-bush kit
New steering box (recon)
New gearbox output shaft/transfer box input shaft
New oil seals (or should I leave the Disco to self preserve  ;D ;D ;D
New top end i.e. rocker shafts, cam, tappets, timing chain........
New sunroof seals
The alarm / Spider binning  >:( and replacing
Good servicing all oils replacing.
UNDERSEAL it, or just use 10/40 (see above)  ;D ;D ;D
Then I can get the LPG done  8) 8) 8)
That'll keep me going for  bit  :o then I got to sort out the bloomin electrics, had a bit of a go today got central locking back now, interior lights next along with Dash lights.
The Sheriff
Re: Discvoery 1 v8 project
« Reply #1 on: 01 October 2014, 19:52:32 »
You picked the wrong time of year to make a start on that lot.
chrisgixer
« Reply #2 on: 01 October 2014, 19:54:06 »
Why? Not too hot, not too cold. Perfect for car work. :y
The Sheriff
« Reply #3 on: 01 October 2014, 20:01:02 »
It will be before Jason gets that little lot done.
chrisgixer
« Reply #4 on: 01 October 2014, 20:04:32 »
Oh well. There's always next year :). ( :-[ )
Crazycarzowner
« Reply #5 on: 01 October 2014, 20:05:54 »
First 3 items should only take a weekend, steering box I'm planning 2 days as its a bit fiddly and I'll have to unbolt & re-position the air-con generator temporarily. Gearbox / transfer box??? New territory, first need to see which transfer box I got. It may have to be removed yet  :o
Top end of engine a few days, working on V8's is easy once all the pipework & electrics are outa the way. Only things I ain't looking forward to is the electrics, turned the air blue a few times today and I'm no autospark. The spider is to the Disco as the powersounder is to the Omega  >:(
« Reply #6 on: 01 October 2014, 20:12:06 »
So,
Poly-bush kit
New sunroof seals
Sounds just like an Omega repair list  ;D Be interesting to see how many swear boxes you fill you get on  :y
« Reply #7 on: 01 October 2014, 20:49:37 »
Cam removal on the V8 is interesting and it and the hydraulic followers will be goosed, get a hardened timing chain and gears as they stretch quickly with the standard ones. It's worth a mild cam upgrade to if you can stretch to it
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #8 on: 01 October 2014, 20:56:58 »
Ooh can we see photos please?
Crazycarzowner
« Reply #9 on: 01 October 2014, 21:11:44 »
When I start I'll be making a photo gallery of progress (or not)  ::) Then I'll have to work  out how to stick em on 'ere!
  • Auckland
    • Mazda MPV
« Reply #10 on: 01 October 2014, 21:25:44 »
The early Discovery inherited a lot of it's design from the Range Rover. I have had the gearbox in and out of my 1972 Range Rover several times.
The 4 speed gun-tractor gearbox in the early Range Rovers weighs at least as much as the engine. I did drop the gearbox once without removing the engine (but only once) I find it easiest to lift the engine out first.
I don't know if the same applies to the Disco :-\
