Question about a old pc I just acquired
Started by tigers_gonads, 03 October 2014, 21:33:29
tigers_gonads
Just acquired a old Packard Bell PC with a 2.9 Celeron / 2 gig of ram.
The cunning plan is to use it as a desktop, using a old 19"tv as a monitor.
Right, the motherboard is VGA only but i've only HDMI / RGB / Scart on the TV.
What sort of cheapo graphics card are out there that will plug into the mother board and give me a HDMI output to the screen ?
I will be dumping the Windows XP that's on it and installing Win 7 32 bit Ultimate if that makes any difference  :-\
Kate
Get one with a dvi port and use a DVI to HDMI  cable.
tigers_gonads
cnj
for around £20 you can purchase a graphics card with hdmi output which should slot straight in and give more than adequate video performance and improve on the old one.
Stuart30
Quote from: cnj on 04 October 2014, 14:14:28
Or simply a VGA TO hdmi adapter...couple of pound on ebay.
cnj
my thoughts were that replacing the old card with new will overcome any or all resolution problems that may occur. I have 2x ex school desktops one running win 7 ultimate and the other running win 8.1. the drivers for the desktops will not run the games in win 7 as the graphics chip is not fast enough ! these are machines designed to run win xp, depending what resolution the old tv runs at of course.
Quote from: tigers_gonads on 03 October 2014, 21:33:29
Is that available on disc then  :-\ Got an old PB desktop also but with no o/s  :(
Bigron
Stuart, please forgive me if I am wrong, but as VGA signals are analogue and HDMI signals are digital, wouldn't a converter be needed? I don't think it would work directly.
Ron.
cnj
if you look in the right place all programs are available !!. the only thing is sorting the wheat from the chaff
!, it may take two or three copies to find one that works.
Most video cards now have an HDMI out.
VGA -> HDMI tend to be fairly pricey. DVI (as per Kates pic above) -> HDMI are a pound or 2.
Figureman52
Quote from: Emd on 04 October 2014, 16:32:31
Google Zorin OS9, I have been running the free version on my pc for several months now and it does everything my old XP setup did and more.
Stuart30
#11
Quote from: Bigron on 04 October 2014, 16:38:02
Ron.
Pretty sure ive got a couple here...actually yes you've got me thinking,are they VGA (blue) or the Digital (white) socket.
Going to dig them out and let you know... :-\
Ok so I was half right..actually no I was wrong  ;D
Ive got VGA to Digital and Digital to HDMI adapters.
Quote from: Stuart30 on 05 October 2014, 09:01:06
Ron.
Quote from: Kate on 03 October 2014, 21:47:32
The white DVI sockets can carry both analogue(VGA) signals and digital(HDMI). The adapters that plug in to the DVI sockets are cheap because there is no fancy electronics inside - they just route the signals from the appropriate pins in the DVI socket to the correct pins in the VGA or HDMI socket.
Kate is right - fit a cheap DVI graphics card and plug a DVI>HDMI adapter into the back of it. This will give you a picture but no sound (DVI doesn't do sound).
Kate
Just use one of these. They are very cheap:
