Author Topic: 3.2 Frontera snag  (Read 3239 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
3.2 Frontera snag
« on: 06 October 2014, 17:19:25 »
Family member has just e-mailed me to say she has just got a 3.2 manual LWB limited Frontera with 49,300 miles on it. After getting it home after a few days the the EML and Airbag light has come on. RAC said it was MaF meter and a new Vauxhall part was fitted at £230. After a day lights are now back on. Took it to Vauxhall for Tech2 to be told it's the idle control valve and want £500 to fit one  :o :o. Any ideas ? :-\
Re: 3.2 Frontera snag
« Reply #1 on: 06 October 2014, 17:20:45 »
At that price, it might be worth a clean of the ICV :-\
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 06 October 2014, 17:38:36 »
Frontera uses an Isuzu lump in the 3.2 doesn't it ???,makes for expensive bits :'(
other rides
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #3 on: 06 October 2014, 17:41:37 »
Is it not a Vauxhall 3.2 petrol engine the same as the omega then. Not seen the thing yet as she is 50 miles from me?
henryd
  • west cornwall
« Reply #4 on: 06 October 2014, 17:53:47 »
This is the donkey
http://img1.auto24.ee/auto24/320/032/9884032.jpg
other rides
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #5 on: 06 October 2014, 18:26:55 »
Think I like the vauxhall 3.2 V6 better
4x4
« Reply #6 on: 06 October 2014, 18:33:34 »
Check connections under seat for airbag light,common problem,isuzu engine fitted ,Icv is same as the montrey 4x4,there are is a dedicated breaker for frontera bits on ebay,very good,fronty4x4spares i think they are called .
4x4
« Reply #7 on: 06 October 2014, 18:47:23 »
Quick check on frontera forum,you can use a 2.2 icv BUT you need to swap over the rubber nipple bit,then turn ignition on for 6 seconds,then off for 6 seconds  and repeat 4 times,that resets the Icv and computer learns new part fitted.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #8 on: 06 October 2014, 20:16:56 »
Thanks all I will pass on the advice :y
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
« Reply #9 on: 06 October 2014, 20:28:49 »
turn on the headlights with the engine running and see if the waning lights go out  :y :y common problem that . i have one im breaking if you need any parts  ;)
Missy_MV6
« Reply #10 on: 09 October 2014, 18:09:53 »
Swordfish....empty your inbox  :)
