Author Topic: Towbar mounting bolt torque...  (Read 3263 times)
« on: 07 October 2014, 12:59:40 »
Having slackened the four bolts on one side of the towbar to drop it for repair work, I have nipped them up to clamp the exhaust hanger repair in place. They will need tightening properly...
Question is, what torque should I tighten them to :-\
Re: Towbar mounting bolt torque...
« Reply #1 on: 07 October 2014, 13:00:31 »
Till you fart & then another quarter turn!  ::) ::) ::)
« Reply #2 on: 07 October 2014, 13:08:32 »
No curry for me tonight then... ;D
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #3 on: 07 October 2014, 13:25:09 »
Struth Andy, I've heard it all now !!!! ;D ;D ;D ;D ;D ;D ;D   I can't stop laughing.
Would it be worth passing on to Haynes !!! ;D ;D ;D ;D
Al...with the curry you eat, you will shear the bugger off !!! ;)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #4 on: 07 October 2014, 14:29:27 »
 ;D ;D
Made me laugh did that.   ;D :y
This is all it says on my paperwork.
Recommended torque settings: M8 - 27Nm, M10 - 53 Nm, M12 - 95 Nm, M14 - 150 Nm,
M16 - 214 Nm
    • 530D M Sport, 330i Coupe
« Reply #5 on: 07 October 2014, 18:40:38 »
I checked them once on the old estate we had.... they were all lose!
Tightened them all back up and rechecked after towing a few times and they were still tight.
« Reply #6 on: 07 October 2014, 20:45:56 »
Is 17mm M14 or M16 :-[
« Reply #7 on: 07 October 2014, 20:50:02 »
Neither. M10 bolts generally have a 17mm head.
« Last Edit: 07 October 2014, 20:58:00 by Entwood »
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #9 on: 07 October 2014, 20:55:11 »
The best torque for large nuts n bolts is F.T. :y
Hoof'land storeman.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #10 on: 07 October 2014, 21:20:59 »
Agreed  ;D :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #11 on: 07 October 2014, 21:58:19 »
TAF usually does it :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #12 on: 07 October 2014, 22:19:35 »
Yep, done with a calibrated lean on a breaker bar.
Although, as I have torque-wrenches handy, I do tend to use them when the required figure is readily available.  I did once torque some Jag XK headbolts with a 3/8 torque-wrench which I can't recommend.
