Author Topic: My Pagid discs and pads have arrived.  (Read 16329 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: My Pagid discs and pads have arrived.
« Reply #15 on: 10 October 2014, 19:07:44 »
Had to drill hers out too. And re tap the holes that the calliper bracket secured to as some idiot had got them I at an angle
RIP Paul Lovejoy
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #16 on: 10 October 2014, 19:46:04 »
They certainly look nice and shiny!  :y
The discs are extremely heavy compared the the Corsa items. ;)
What are the 2 small  bolts in the plastic bag for?
There should be 2xm8x15 for the calipers aswell. (13mm spanner size)
Hoof'land storeman.
chrisgixer
« Reply #17 on: 10 October 2014, 20:42:17 »
Riveted shims. Painted discs. Look ok :y
« Reply #18 on: 10 October 2014, 21:04:17 »
They fit into the countersunk holes that secure the disc to the hub  :y
I don't think so, Mr Emd.
The bolts I have don't look like they will fit a countersunk hole.
« Last Edit: 10 October 2014, 21:09:40 by Doctor Opti »
« Reply #19 on: 10 October 2014, 21:09:24 »
This is what I have. :y
There doesn't appear to be the countersunk screws that hold the discs.
« Reply #20 on: 10 October 2014, 21:23:04 »
There won't be... :y bolts relate to the pad fitting kit. There are only two as you only need to remove one bolt to change the pads.
« Reply #21 on: 11 October 2014, 11:25:08 »
Simple job? Good, I like that. :y
biggriffin
Hoof'land storeman.
tidla
  • solihull
« Reply #23 on: 11 October 2014, 22:23:01 »
I recon you have the white gloves , so there's a start.
« Reply #24 on: 12 October 2014, 20:03:30 »
If I break the brake pad wear sensor, or, if it has already been snapped off by a previous mechanic/neanderthal.........do I need to replace it?
I'm really not bothered unless it is essential.  :y
« Reply #25 on: 12 October 2014, 20:52:27 »
Cable tie it to the ABS wiring :-X
  • Online Online
« Reply #26 on: 12 October 2014, 22:09:27 »
No. Chop the white end off, bare back the two wire ends & twist them both together. Wrap up in insulation tape and then cable tie to the ABS wiring  ::)  ;) ;)
« Reply #27 on: 12 October 2014, 22:19:26 »
Dont let Aaron here you say that  ::) ;D :-X
  • Online Online
« Reply #28 on: 12 October 2014, 22:35:16 »
i would hope he was equally scathing of tying it to the ABS sensor too  ::) ............
I'd buy a new sensor (there's only one on Dr O's car anyway! - the tight bugger  ;) ;) )
« Reply #29 on: 12 October 2014, 22:37:22 »
I think Emd is referring to my comments on Webby's ABS sensor wiring repair, entombed with insulation tape ;D
