Author Topic: 2 questions  (Read 4216 times)
pauls
  • By the sea minehead
    • Bmw x3
2 questions
« on: 11 October 2014, 16:29:41 »
First one. What is hidden behind the front drivers wing..
Second one. When using the heating/Air con controls in my old green one when you turned it up or down it showed you with the display going up and down, it also stayed litup. my new car seems to show it while you are turning the button it then disapears. Is this correct or is the unit on the way out.
powerslinky
Re: 2 questions
« Reply #1 on: 11 October 2014, 16:44:25 »
1.   Air pump/compressor  for rear shocks if an elite with air suspension
2.   Climate control should show set temp constantly while switched on    (I think . .  . has on all my FL 's )
Re: 2 questions
« Reply #2 on: 11 October 2014, 16:54:07 »
Offside front wings contain, from back to front, working clockwise:
1. Carbon cannister. Feeds petrol vapour from the tank to the inlet manifold via the purge valve (at the back of the 135 head on v6s).
2. Xenon level control ECU. Located behind the headlight housing, only properly accessible with the wing removed.
3. Suspension self leveling pump, where fitted, Plod estates and all Elites iirc. Technically doesn't count as it's behind the bumper...
Hth :y
« Last Edit: 11 October 2014, 16:55:48 by Doesn't play well with others... »
pauls
    • Bmw x3
Re: 2 questions
« Reply #3 on: 11 October 2014, 17:07:18 »
Thanks chaps So it the air pump I keep hearing. :y
Reference the air con controls. I thought it should stay on. Can I do a reset or do I need a new one.
chrisgixer
Re: 2 questions
« Reply #4 on: 11 October 2014, 19:45:18 »
Reset won't hurt.
Might need ignition in position 2. Press and hold off and auto simultaneously.
chrisgixer
Re: 2 questions
« Reply #5 on: 11 October 2014, 19:47:44 »
Can't think why the display would go off on drivers side though.
Re: 2 questions
« Reply #6 on: 11 October 2014, 20:22:17 »
Left hand drive config perhaps :-\
chrisgixer
Re: 2 questions
« Reply #7 on: 11 October 2014, 20:46:29 »
....if it didn't come on when adjusted, then yes possibly. As I understand it anyway. :-\
chrisgixer
Re: 2 questions
« Reply #8 on: 11 October 2014, 20:47:06 »
Sticky button/dial knob maybe?
Stuart30
Re: 2 questions
« Reply #9 on: 11 October 2014, 21:37:11 »
Hth :y
Hope the OP doesn't mind...im getting a whiff of petrol when driving,some times very faint other times pretty strong.
Had a look under bonnet but nothing obvious...just wondering if these leak or break down etc.
pauls
    • Bmw x3
Re: 2 questions
« Reply #10 on: 11 October 2014, 22:12:25 »
Its not the drivers side its the fan speed display that goes out after ajusting.on the passenger side.
chrisgixer
Re: 2 questions
« Reply #11 on: 11 October 2014, 22:51:13 »
is "auto" showing?
Re: 2 questions
« Reply #12 on: 12 October 2014, 04:56:48 »
Sounds like a failing display then :-\
pauls
    • Bmw x3
Re: 2 questions
« Reply #13 on: 12 October 2014, 09:47:30 »
chrisgixer
Re: 2 questions
« Reply #14 on: 12 October 2014, 10:23:40 »
 The bars disapear, but the fan simble stays on..?
