Author Topic: Cable Cutter  (Read 2348 times)
amba
  • Medway towns
    • German V6
Cable Cutter
« on: 14 October 2014, 22:30:31 »
Can anybody point me in the right direction for sourcing a wire cutter that will just expose the internal core without cutting through..ie just removing a small section of the outer sheath.
Sure I saw such a tool but cant for the life of me find it by searching...want to tap into live feed on wiring loom but would prefer not cutting right through entire cable
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Cable Cutter
« Reply #1 on: 14 October 2014, 22:49:01 »
If you're trying to remove a section from the middle of the wire, then I doubt you'll find a tool to do it. A new, sharp Stanley knife blade to gently cut the insulation but not the wire, is probably your best bet. I suspect you could find such a thing without too much trouble.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Cable Cutter
« Reply #2 on: 14 October 2014, 22:53:41 »
I have something similar to this http://www.amazon.com/gp/aw/d/B0002KR95W?pc_redir=1413154326&robot_redir=1
but will only work on the ends of wires...
amba
  • Medway towns
    • German V6
Re: Cable Cutter
« Reply #3 on: 14 October 2014, 22:58:38 »
Sure I saw such a cutter on TV sometime ago.
Seem to remember it cut through the outer plastic sheath at 2 points about 20mm apart then as NickW said you needed to join the 2 cut sections with a sharp blade to remove that section exposing the inner core without cutting through the entire cable
Re: Cable Cutter
« Reply #4 on: 14 October 2014, 22:59:25 »
Bought a halfway decent laser one from Helfrods... £15ish iirc :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Cable Cutter
« Reply #5 on: 14 October 2014, 23:23:32 »
Some Crimp Tools for Red, Blue, Yellow Bulliet or Inline Crimp connectors have a   cutting tool, personally I would just use a knife or stanley, the blunter the better so it wont cut the centre strands, takes seconds to do, well it does for me. :-X
Re: Cable Cutter
« Reply #6 on: 14 October 2014, 23:37:25 »
Can anybody point me in the right direction for sourcing a wire cutter that will just expose the internal core without cutting through..ie just removing a small section of the outer sheath....
Something like this http://www.ebay.co.uk/itm/6-WIRE-STRIPPING-PLIER-CUTTER-ELECTRICAL-STRIPPER-HARDENED-EDGE-HEAVY-DUTY-TOOL-/181478154928?pt=LH_DefaultDomain_3&hash=item2a40f0e2b0  :-\  :y
Re: Cable Cutter
« Reply #7 on: 15 October 2014, 00:11:01 »
+1 used a tool like this for years, works fine, even on heavy auto cable........ :y :y
amba
  • Medway towns
    • German V6
Re: Cable Cutter
« Reply #8 on: 15 October 2014, 08:08:34 »
Thanks guys for the pointers and advise.
Much appreciated :y
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Cable Cutter
« Reply #10 on: 15 October 2014, 10:05:14 »
a bit off-topic but this tool works great on V6 breather tube clips  :y
