Author Topic: water works??  (Read 3604 times)
peter the butcher
  • knaresborough, north yorkshire
  • omega driver as a hobby and now retired :-(
    • 2.6CDX
water works??
« on: 19 October 2014, 06:13:22 »
Hi everyone,
OK, so never had a problem with the old girl yet  :)
But now???? the "check coolant level" flashed up, once week before last, duly topped it up, and again yesterday. I put a drop of water in the tank, that put off the warning sign. but lo and behold, it came back on 4 miles down the road in York, as I reversed into a parking bay at a pub to meet someone, I noticed a water trail that the car had left.
The temp gauge was fine, as always, there was hot air, as should be.... but whilst having a look for a split hose under the bonnet, I though, check the oil filler cap, and sure as eggs are eggs, mayo on it, that was not there the other week.
So, any suggestions as to what it may be, and IF its is the cylinder head  :'( :'(
 anyone want to do it, will travel from here for a day or 2
chrisgixer
Re: water works??
« Reply #1 on: 19 October 2014, 07:28:25 »
Defo not HG with JUST the Mayo as a symptom. Ignore Mayo on filler cap. Just means short journeys and condensation in the cooler air of the filler neck that sits away from the engine.
Check HBV back of engine under scuttle for leaks, with cc set in hi and then lo. If ok report back :y
peter the butcher
    • 2.6CDX
Re: water works??
« Reply #2 on: 19 October 2014, 15:58:32 »
Check HBV back of engine????
am a complete numpty :D :D
chrisgixer
Re: water works??
« Reply #3 on: 19 October 2014, 16:16:55 »
Heater by pass valve. TIS a little bugger for leaks.
Sometimes described as the star ship enterprise.
Top 4 images
https://www.google.co.uk/search?q=vauxhall+omega+hbv&biw=1024&bih=649&source=lnms&tbm=isch&sa=X&ei=NdVDVKjjFuOz7gbemIHoCQ&ved=0CAYQ_AUoAQ
chrisgixer
Re: water works??
« Reply #4 on: 19 October 2014, 16:17:38 »
To add. There are other causes, but hbv most common.
peter the butcher
    • 2.6CDX
Re: water works??
« Reply #5 on: 19 October 2014, 16:42:37 »
will have  a gander at it tomorrow at work,
 am putting the car up on a ramp as well, to blow compressed air up the passenger side scuttle drain pipe, as I can not get my hand down to make sure its clean, as I do not want another carpet wetting again >:( >:(
Peter
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: water works??
« Reply #6 on: 19 October 2014, 16:45:31 »
And that's why it is worth throwing £20 at a new one.
omegod
  • liverpool
    • 2017 Seat Ateca
Re: water works??
« Reply #7 on: 19 October 2014, 18:15:58 »
Peter
A bit of stiff wire works well too!
peter the butcher
    • 2.6CDX
Re: water works??
« Reply #8 on: 19 October 2014, 18:21:26 »
Peter
got as a permanent fixture on the back seat ;D ;D ;D just incase
peter the butcher
    • 2.6CDX
Re: water works??
« Reply #9 on: 29 October 2014, 13:59:58 »
anyone got a part number for the HBV, please
 have looked at 4 various sites, and nothing is found, it says
peter
Re: water works??
« Reply #10 on: 29 October 2014, 14:43:09 »
Local dealer probably carries it as a stock item :y
Not worth buying pattern/ebay special imho... :-\
chrisgixer
Re: water works??
« Reply #11 on: 29 October 2014, 16:04:26 »
I keep a spare in the boot. In the same box as the spare crank sensor. ;)
Re: water works??
« Reply #12 on: 29 October 2014, 22:06:01 »
£20 - when did you last buy one? ???
peter the butcher
    • 2.6CDX
Re: water works??
« Reply #13 on: 30 October 2014, 15:31:04 »
well just rang my local dealer (bristol street motors) a mile away from here, and they want........ £14 plus VAT, bloody good is that. just need to fit it then, and hopefully that will stop me having to fill the reservoir every 2 days
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: water works??
« Reply #14 on: 31 October 2014, 21:12:56 »
Buy 10 and sell them on here.
Page created in 0.027 seconds with 16 queries.
