Author Topic: Oh shite, oil leak help  (Read 5606 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 19 October 2014, 13:01:27 »
Okay, just replaced the oil cooler / full oil and filter change.
Filled it up with water and fresh oil and turned the key.
It fires up first time with no problems.
Had a look underneath as you do only to see fresh engine oil pishing down behind the block  >:(
Got underneath there with the torch expecting to see it coming from around the filter housing only to find it is coming out of (what looks) like a hole in the block above the filter housing, near the down pipe / exhaust manifold  :o >:(
Anybody got any ideas on this please ??
I'll try and take a picture later when I get these pigging oil soaked clothes off  >:(
Re: Oh shite, oil leak help
« Reply #1 on: 19 October 2014, 13:07:24 »
The oil cooler pipes bolt into the block around about there
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #2 on: 19 October 2014, 13:10:10 »
Did you bend the cooler pipes or take them off if you bent them out the way probably cracked one and oil coming out.  :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 19 October 2014, 13:21:14 »
I'm just charging my camera batteries now but it looks to me that its coming from the engine block above where the oil cooler pipes are   :(
Yes, the pipes was undone at both ends
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 19 October 2014, 13:33:46 »
Is they a oil core plug around there ?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 19 October 2014, 13:50:45 »
Apologies if these are a bit big
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #6 on: 19 October 2014, 13:57:06 »
It could be the top end of the oil pipes not seated properly  :-\ was there oil there before you did the work if not then it will almost certainly be something you have done i:e not tightened properly or seal not seating  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 19 October 2014, 14:03:34 »
Everything was oil free before I started  >:(
I'm beginning to think that one of the pipes onto the oil cooler hasn't sealed properly  :-\
The front of the car is well and truly jacked up so any leak would flow straight back towards the back of the engine and work its way down  :-\
Opinions please before I pull the plenum / fannymold off AGAIN  ::) :'(
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #8 on: 19 October 2014, 14:07:27 »
So dry before and now oil then it must be the pipes not seating properly even so you need to take the plenum off to get a proper look  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 19 October 2014, 16:24:45 »
For Sale
Various body parts from a ham fisted git18 year old son who over tightened the piggin front banjo bolt on the oil cooler causing it to fracture and leak nice fresh oil all over my clean engine and nearly cause me to have another nervous breakdown  >:( >:(
Body part prices available on request  :y
All body parts must be collected in person  ;D
Cash only (no PayPal)  ;D ;D ;D
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #10 on: 19 October 2014, 16:47:26 »
Oh noooo make him pay for a new cooler.  :y :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 19 October 2014, 16:51:34 »
Managed to tap out what was left of the old bolt with a hammer and screwdriver so its just a case of new washers and a bolt  :(
Oh believe me, I won't let him forget this in a hurry  ;) ;D ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #12 on: 19 October 2014, 17:17:41 »
For Sale
Bet we know what bits stemo will want :D
Hoof'land storeman.
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #13 on: 19 October 2014, 20:20:24 »
For Sale
alway said kids cost an arm and a leg ;D
i'll shut the door on the way out....... ;D
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #14 on: 19 October 2014, 22:19:40 »
jeez you was lucky there, sorry it all went tits up for you.
at least its an easy fix.  ;)
