Author Topic: Oil Leak at bottom of sump  (Read 2436 times)
m.ian
« on: 22 October 2014, 13:03:37 »
Have had pug and oil level sensor replaced but still dripping oil.
Been told that the oil sump pan maybe porous??????
How do I check? And where do I get a replacement?
Temetsy
  • Finland
    • b1 x25xe sedan
Re: Oil Leak at bottom of sump
« Reply #1 on: 22 October 2014, 16:10:12 »
First step is to look the exact spot where it's leaking :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #2 on: 22 October 2014, 16:11:57 »
Get it well cleaned, then wait a day / few days to discover. Also don't forget an oil leak doesn't have to be coming from the sump - may be dribbling down from anywhere - including the camcovers. Have you cleaned your breathers lately?  :)
m.ian
« Reply #3 on: 22 October 2014, 17:00:59 »
Yes breathers cleaned a couple of weeks ago and leak is at the bottom of engine very low down.
Temetsy
  • Finland
    • b1 x25xe sedan
« Reply #4 on: 22 October 2014, 17:35:26 »
Oil filter housin or sump gasket propably, but as Geezer said clean up engine and after few days check to see what parts are oily :)
« Reply #5 on: 22 October 2014, 17:41:53 »
Sumps have two gaskets as they're two piece... Front crank seal is another firm favourite. Any leaks from here drain everywhere...
« Reply #6 on: 22 October 2014, 18:34:09 »
Oil pressure sensor, dipstick, oil pump...  ...so many places.
I feel your pain, having spent since before Guffer's big meet chasing an oil leak, unsuccessfully.
    • 530D M Sport, 330i Coupe
« Reply #7 on: 22 October 2014, 21:01:33 »
Mind you, a bit of oil on the sump pan stops it rusting.
Temetsy
  • Finland
    • b1 x25xe sedan
« Reply #8 on: 22 October 2014, 21:08:08 »
That's why my old carlton had factory new bottom  :D
