Author Topic: MOT advisories.  (Read 3492 times)
MOT advisories.
« on: 25 October 2014, 17:02:39 »
1......Front to rear brake pipes slightly corroded.
2......Nearside rear brake disc worn, pitted or scored,but not seriously weakened.
3......Offside rear brake disc worn, pitted or scored, but not seriously weakened.
4......Nearside front tyre worn close to the legal limit
5.....Offside front tyre worn close to the legal limit
6.....Offside rear tyre worn close to the legal limit
7.....Nearside rear tyre worn close to the legal limit
8.....Nearside front lower suspension arm ball joint dust cover deteriorated, but preventing the ingress of dirt.
9.....Offside front lower suspension arm ball joint dust cover deteriorated, but preventing the ingress of dirt.
10.....Nearside front lower suspension arm ball joint dust cover deteriorated, but preventing the ingress of dirt.
11.....Nearside front upper suspension arm ball joint dust cover deteriorated, but preventing the ingress of dirt.
12....Nearside front vehicle structure has slight damage.
13....Offside front vehicle structure has slight damage.
14.... Nearside front inner gaiter split.
15...Nearside wiper slightly deteriorated.
Total cost to rectify?:)
Re: MOT advisories.
« Reply #1 on: 25 October 2014, 17:04:47 »
£50 for an MoT at a less bored garage ::)
Or £1200 for an Alfa 156 ;D
Re: MOT advisories.
« Reply #2 on: 25 October 2014, 17:17:19 »
He won't shift on the price, Al. :-\
Mot to Nov 2015. :y
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: MOT advisories.
« Reply #3 on: 25 October 2014, 17:18:12 »
So,
Wire brush and a spray over with suitable primer for the brake line - £5.00
4 Tyres - £200 - £400, depending on whether you care or not
Rear Discs - Not a fail, so more than likely perfectly fine - FREE
Ignore the ball joint covers if they are doing their job - FREE
Slight damage?  Tester is a tosser - FREE
So apart from Tyres and a pair of Wipers (normal service items)........
It won't cost a lot.
chrisgixer
Re: MOT advisories.
« Reply #4 on: 25 October 2014, 18:11:23 »
A bit of basic servicing and non pattern parts from the owner. ;)
What car is this on?
Re: MOT advisories.
« Reply #5 on: 25 October 2014, 18:45:52 »
Sounds like a lot of arse covering .....  ::)
Re: MOT advisories.
« Reply #6 on: 25 October 2014, 19:13:35 »
Presuming this is for the mighty Alfa  ::) ... 200 notes then to fix it , barter him down  :(
Re: MOT advisories.
« Reply #7 on: 25 October 2014, 19:41:52 »
It has just entered my head that the road tax may be in the top bracket...... just like Andy B....eanz Merc.
Car was registered in October 2006 and I'm guessing that it throws out plenty of carbon crap.
« Last Edit: 25 October 2014, 19:45:49 by Doctor Opti »
joshwyatt
  • Oxford
Re: MOT advisories.
« Reply #8 on: 26 October 2014, 00:41:57 »
VED for your vehicle in question would be £275 for 6 months, and £500 for 12 months. It puts out 283g/km of Co2.
Re: MOT advisories.
« Reply #9 on: 26 October 2014, 10:55:39 »
 :o :o :o Thanks, Mr Joshwyatt. That is a kick in the balls. Roughly 50% of the cost of the car.
I wonder if he would accept £700?.....That way I could tax the car free of charge for the first year. :y
Re: MOT advisories.
« Reply #10 on: 26 October 2014, 21:45:49 »
Sheesh  :o Just makes more sense to keep the Omega then . Mid life crisis can cost you a lot of wedge  ::)
Re: MOT advisories.
« Reply #11 on: 26 October 2014, 22:02:19 »
[/quote]
It's less than a tenner a week  :y :y :y
Re: MOT advisories.
« Reply #12 on: 26 October 2014, 22:53:06 »
[/quote]
No...it's £500 out of the blue. :-\
I was never much of a saver. :-\
Re: MOT advisories.
« Reply #13 on: 26 October 2014, 22:57:07 »
[/quote]
I have wads of notes lying around the place ............... I just use one of them when the VED is due for renewal  ::)
Re: MOT advisories.
« Reply #14 on: 26 October 2014, 23:15:34 »
[/quote]
I sympathise with that, but under the new system, it's £51 per month :y
Not trying to talk you into it, honest... ::)
