Pages: 1 [2] 3  All   Go Down
Author Topic: Gravy wont disappear  (Read 6780 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Gravy wont disappear
« Reply #15 on: 29 October 2014, 13:15:05 »
There's a very effective method for blowing that shit out once it's proper mayonnaise, also involves a box of Aerial Liquitabs, asbestos arms, about 200 litres of water and drive cleaner for afters...
But as said, new oil cooler then worry about cleaning it out. Avoid driving it if at all possible. :y
Just don't use the power washer to flush the radiator either or you will end up with a cracked core  ::) :-[
« Last Edit: 29 October 2014, 13:16:46 by tigers_gonads »
« Reply #16 on: 29 October 2014, 13:22:44 »
Last car I cleaned out, we attached the hose alternately to either the radiator drain plug or the expansion tank overflow pipe into the rad, dropped three tabs down the top hose, ran the engine until the temp gauge hit 100, then simply popped the cap off. Once the resulting volcano has calmed down, skim the gunge from the header tank and repeat... twenty times ::)
The rapid expansion of the water in the sytstem helps blow the muck out, and by alternating opposite corners of the rad, that ensures it gets flushed too :y
To add, when the hose is connected to the drain plug, the hose from the expansion tank to the radiator is removed from the radiator and diverted to a bucket.
When the hose is connected to this pipe, the drain plug is closed :y
Edited for clarity :y
« Last Edit: 29 October 2014, 13:39:08 by Taxi Al »
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #17 on: 29 October 2014, 13:26:06 »
 ;D
You aint got a vid of this per chance have you?  ;D Frothing Omega
RIP Paul Lovejoy
« Reply #18 on: 29 October 2014, 13:35:38 »
It would make a good Youtube 'How not to flush a cooling system' video, but it is very effective. Definitely not one for the Health and Safety brigade and therefore not exactly recommendable :-X But it does work 8)
« Reply #19 on: 29 October 2014, 14:02:54 »
It cost me £220 plus a bottle of Glenlivet to replace.
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
« Reply #20 on: 29 October 2014, 15:14:03 »
OOOps.. Is that what I think it is? :-\
Have you just replaced the oil cooler?
No...ive just flushed out the cooling system.
Still learning...Be nice!
Anthony in Madrid
  • Valencia, Spain
« Reply #21 on: 29 October 2014, 15:31:58 »
A video or pics of this would be great. However repeating it 20 times...Does that mean adding the tabs 20 times too?
Anthony in Madrid
  • Valencia, Spain
« Reply #22 on: 29 October 2014, 15:37:39 »
Was the water running all the time while the engine was on?
« Reply #23 on: 29 October 2014, 15:50:57 »
Yes.
« Reply #24 on: 29 October 2014, 15:54:26 »
Sorry, no vid or pics, and to answer your question... yes, so buy a big box (diswasher liquid tabs):y
No point flushing until the oil cooler has been replaced... has this been done yet? I can't remember if this was the issue you were having recently :-[
chrisgixer
« Reply #25 on: 29 October 2014, 16:08:14 »
Change the oil cooler and flush immediately.
Continual use will bugger the rubber compenents and block the heater matrix, making flushing a much more prolonged process with detergents that eat aluminium.
The matrix is prone to leaks on cars this age as it is, without this extra agro.
Anthony in Madrid
  • Valencia, Spain
« Reply #26 on: 29 October 2014, 17:45:17 »
No havent changed the oil cooler yet. Looking on the net to buy one. If anyone has one or a good place to buy that ships please recommend. Cheers
Ant
Anthony in Madrid
  • Valencia, Spain
« Reply #27 on: 29 October 2014, 17:46:40 »
Yes.
So the water was just building up inside the system without an outlet? Is this dangerous?
Anthony in Madrid
  • Valencia, Spain
« Reply #28 on: 29 October 2014, 17:48:53 »
Asbestos arm?
Drive cleaners as in Clean the front drive of the house?  :(
« Reply #29 on: 29 October 2014, 18:17:54 »
When you release the expansion cap on a hot engine the pressure releases suddenly... This principle effectively blows the gunge out from the header tank. Only catch is that it goes everywhere and is clearly quite hot. The overflow when the hose is filling via the radiator drain goes into a bucket, which helps to wash some of the muck through... You need heat and the tabs to  shift the muck, and by adding water you're adding fluid which flushes the crud out of the system via the header tank.
Best done on waste ground, ie a scrubby bit of garden rather than a block paved drive, hence the drive cleaner... Even traditional flushing will make a mess :y
Pages: 1 [2] 3  All   Go Up
