Author Topic: Qmax arrived - time to cut the panel!  (Read 1110 times)
« on: 25 June 2008, 11:24:43 »
Well it's here!
I presume I drill an initial central hole for the bolt, and then just put one bit each side, and do up the big one?  ::)
Very nervous here  ;D
Re: Qmax arrived - time to cut the panel!
« Reply #1 on: 25 June 2008, 11:28:18 »
You could practice on the "Satan CDX" first?
« Reply #2 on: 25 June 2008, 11:56:30 »
I've done it - it's made a lovely hole, so smooth I can run my fingers inside it :y
Phew, sweat over ;D
Any good rustproofing tips before I fit the filler? :y
« Reply #3 on: 25 June 2008, 11:57:52 »
Grease is probably the best answer.
I was going to add that I put a fine wipe of grease on the hole cutter threads and a spray of cutting oil on the cutter.....but you have already cut the hole  :y
« Reply #4 on: 25 June 2008, 18:08:22 »
Phew, sweat over ;D
Jeremy mentioned some kind of sealant but I can't remember what!!!  ::) ::) ::) ::)
I haven't got to worry because he's said he'll cut my hole and fit the filler for me!!!  :y :y :y :y :y
