Author Topic: geometry  (Read 4591 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
geometry
« on: 30 October 2014, 11:27:05 »
well went and got all for wheels aimed in the right direction.
 went to a place recommended to me by Mr dbug :y
 arrived, was given a coffee, car taken away, not allowed in workshop area (effing safety),
 was charged £70.00 this was reduced to £65.00 as the nice Mr dbug turned up, and got me some discount Nice to meet you sir and thanks for the discount :y :)
[/img]
« Last Edit: 30 October 2014, 11:28:39 by biggriffin »
Hoof'land storeman.
Re: geometry
« Reply #1 on: 30 October 2014, 12:14:05 »
That's alot of camber... (except nsr, which is near enough) front should aim for 1°10' and rears somewhere between 1°30' and 1°40' :-\
Not sure when 0°05 + 0°08 equalled 0°10 either, but fair play on getting it done at that price :y
Re: geometry
« Reply #2 on: 30 October 2014, 12:58:19 »
Thought you used the string method  ;D Nice to know though that there is other places to get it done  :y
biggriffin
Re: geometry
« Reply #3 on: 30 October 2014, 14:29:42 »
The pound shop had run out of string,so had to resort to a pretty picture instead..
Hoof'land storeman.
biggriffin
Re: geometry
« Reply #4 on: 30 October 2014, 14:36:31 »
The fronts wouldn't adjust more than is shown,that was max, on the uprights without removing them and elongating the holes. But its a road car at the end and 1' isn't going to make a difference to my getting to work, there will be some who wont like them figures, but its not a grp A or super saloon.
Hoof'land storeman.
Re: geometry
« Reply #5 on: 30 October 2014, 16:22:02 »
Fair dos :y
Re: geometry
« Reply #6 on: 30 October 2014, 17:49:09 »
I'm a bit concerned they couldn't get the front camber far better. Is there something odd with your car preventing it?
biggriffin
Re: geometry
« Reply #7 on: 30 October 2014, 18:11:13 »
There was no more adjustment,on the uprights.
Hoof'land storeman.
Re: geometry
« Reply #8 on: 30 October 2014, 18:56:37 »
Yeah, I got that, the question is, why?  What shocks, hub and wishbones do you have?
biggriffin
Re: geometry
« Reply #9 on: 30 October 2014, 19:23:55 »
Std MV6. 17"  poly bushes, gm drop links.
Hoof'land storeman.
Magwheels
    • 2.2 dti Elite saloon
Re: geometry
« Reply #10 on: 30 October 2014, 19:36:50 »
Far to much front camber for a road car, that will knacker the tyres in no time!!
Was you pulling the top of the wheel out or pushing the bottom in?
Think it may need both doing.
If pushing in it must be lowered or something wrong with it.
« Last Edit: 30 October 2014, 19:39:23 by Magwheels »
Re: geometry
« Reply #11 on: 30 October 2014, 20:39:19 »
Depending on tyre rim protection, you should be able to get the wheel virtually upright, certain above -1 degree  :-\
Both sides at the end of their travel, or just one side, and the other set to match?
Re: geometry
« Reply #12 on: 30 October 2014, 21:49:05 »
Well looks like that was a waste of £65 biggriff!  ::)  Bet you wish you'd stuck with your bit of string now!  ;D
tidla
  • solihull
Re: geometry
« Reply #13 on: 30 October 2014, 22:44:51 »
Had a zifira in with the same problem. Excessive tyre wear on the inside, camber way out.
The only way to get the adjustment anywhere near was to ream out the adjustment hole a tad.
Re: geometry
« Reply #14 on: 30 October 2014, 23:00:28 »
Nice to meet you mate, and I won't ask for the extra discount ;) - some say it should go to WIM  ;D ;D ;D ;D
Suprised re the front camber figs - whilst they didn't get mine to exactly 1°10', they got it close enough (within about 10' -  20' from memory) - same reason given to me at the time as given to you.
However I found car much more planted since geo done, and slight wear on inside edge of front o/s tyre has not got any worse since.
Does the car drive any better since you had it done?
