Author Topic: Heavy steering  (Read 4608 times)
woolley11
  • York
    • 3.0 MV6 auto
Heavy steering
« on: 04 November 2014, 19:31:37 »
My pfl has started with heavy steering - I've noticed a bit of dampness around the reservoir ?
What could this be ? - the level looks OK
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
Re: Heavy steering
« Reply #1 on: 04 November 2014, 19:42:25 »
all fuses intact?  :-\
I'm sure someone/Rob will say which  :y
chrisgixer
Re: Heavy steering
« Reply #2 on: 04 November 2014, 20:22:52 »
Intermittent heavy at speed, servo tronic relay.
Heavy at low speed, while parking manouvering, tired pas pump.
Most reservoirs leak slightly. Nothing unusual there.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Heavy steering
« Reply #3 on: 04 November 2014, 20:27:53 »
Press the throttle until you attain around 3k revs. then rotate the wheel.  As you are rotating, take your foot off the pedal.  If it stiffens (ooh err Missus), then the pump it knackered.  If it stays the same, heavy, look elsewhere first.
chrisgixer
Re: Heavy steering
« Reply #4 on: 04 November 2014, 20:51:22 »
....and take it out of gear first obviously ;D wahaay ;D
woolley11
  • York
    • 3.0 MV6 auto
Re: Heavy steering
« Reply #5 on: 04 November 2014, 20:54:42 »
Thanks guys - what's this fuse malarkey ?????
Didn't know there was one for the pas - I'll have a look at that first then do the test with revs  :y
Omega 3.0 MV6 pfl
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Heavy steering
« Reply #6 on: 04 November 2014, 20:59:14 »
I'd guess the fuse would be for the pas pressure circuit but don't quote me on that
RIP Paul Lovejoy
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: Heavy steering
« Reply #7 on: 04 November 2014, 21:46:00 »
From memory I don't think PFL have a fuse for power steering
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Heavy steering
« Reply #8 on: 04 November 2014, 21:48:38 »
Any system with Servotronic will have a fuse.  :y
plym ian
  • Plymouth, Devon
Re: Heavy steering
« Reply #9 on: 04 November 2014, 22:20:59 »
Sorry I'm wrong v6 do 4 pots dont :)
Re: Heavy steering
« Reply #10 on: 04 November 2014, 22:30:07 »
it has a relay in it too (as Gixer says) ..... all to do with the speed sensitive side of your power steering
Re: Heavy steering
« Reply #11 on: 04 November 2014, 22:53:59 »
Fuse #14
woolley11
  • York
    • 3.0 MV6 auto
Re: Heavy steering
« Reply #12 on: 05 November 2014, 21:09:52 »
Looked for fuse #14 - I assume it's the batch under the steering wheel but appears to be heated seat.
Or is it one of the engine bay ?
Omega 3.0 MV6 pfl
Magwheels
    • 2.2 dti Elite saloon
Re: Heavy steering
« Reply #13 on: 05 November 2014, 21:16:14 »
Quote from: chrisgixer link=topic=127087.msg1622052#msg1622052 date=1415132572
[/quote
Mine was the other way around, heavy at parking, fairly normal on the move, no variable assistance, it goes back to a default mode. Turned out the big red/orange relay looking box ( left kick panel under glove box) had been full of water at some time. Changed for a used one and hey presto nice and light when parking getting heavier at speed. Easiest way to find out is to pull the red control unit and see if it makes any difference. I don't think my diesel has one!! :'( :'(
    • 530D M Sport, 330i Coupe
Re: Heavy steering
« Reply #14 on: 05 November 2014, 21:34:23 »
DTi Elite's have Servotronic, The red relay was under the steering column on mine rather than behind the glovebox.
