Author Topic: Saturn vue 3.0 v-6  (Read 2243 times)
Saturn vue 3.0 v-6
« on: 11 November 2014, 20:20:04 »
I believe the Saturn vue 3.0 v-6 uses the same engine as the Omega , correct  ??? Interesting Utub videos on engine part replacements  ;) Maybe our American friends can confirm , or even English ones  :)
The Sheriff
Re: Saturn vue 3.0 v-6
« Reply #1 on: 11 November 2014, 20:23:35 »
Did you put that avatar on for Opti?  ;D
« Reply #2 on: 11 November 2014, 20:29:48 »
 :D
Look what our american friend found where the stat hides  :( Different plenum on these cars ..
Stat
« Reply #3 on: 11 November 2014, 21:12:15 »
Yes who would put the stat there?  ::)
That all in one plenum/intake manifold must be a right bastid to get out, seeing as they don't just lift out.  :-\
« Last Edit: 11 November 2014, 21:14:28 by Sir Tigger »
« Reply #4 on: 11 November 2014, 22:56:23 »
 :D
Stat
And presumably component location has sod all to do with what chassis the engine is fitted to, especially as it's wwd... ::)
Is it really too much too apply a touch of common sense/imagination :-\
« Reply #5 on: 12 November 2014, 08:20:15 »
The stat is actually perfectly positioned from a design/operation perspective.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 12 November 2014, 08:27:55 »
The stat on a 3.0l Ford V6 is in a similar place, it just has less stuff around it.
« Reply #7 on: 12 November 2014, 15:13:14 »
And in what decade was that designed
« Reply #8 on: 12 November 2014, 15:27:00 »
I would suggest that it was before yourself, and Nick W were even thought of... ::)
« Reply #9 on: 12 November 2014, 15:56:36 »
Ive been putting off replacing the stat for a year now  :-[ I know its not a bad job albeit that B bolt shinanigan  ::)
« Reply #10 on: 12 November 2014, 16:03:02 »
Even with that bolt, it's a doddle to change :y
    • 530D M Sport, 330i Coupe
« Reply #11 on: 12 November 2014, 20:51:05 »
That inlet / plenum setup looks the same as the one on the 3.2 Vectra C.
« Reply #12 on: 13 November 2014, 10:32:28 »
I think they had to wait for petrol to be invented before they could test it. ;D Good job it had maritime uses in the meanwhile (on the end of a chain). ;D
