Author Topic: 2.0DTi Glow plugs  (Read 1898 times)
2.0DTi Glow plugs
« on: 21 November 2014, 16:01:50 »
I vaguely recall somebody saying to warm the engine first. Or did I dream that bit?
I certainly never did on the TD Tractor.
Guess what I'm doing tomorrow morning ;D
Re: 2.0DTi Glow plugs
« Reply #1 on: 21 November 2014, 16:30:35 »
If you can get it started ;D
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 21 November 2014, 16:32:59 »
Certainly will help on an ally head,they can be a bastid to get out :-X
other rides
Crazycarzowner
« Reply #3 on: 21 November 2014, 16:48:49 »
I did all six on my Skoda recently, What I did was take it out for a warm up, up to operating temperature, drove it straight in the garage, then using a deep 10mm socket sat squarely on the plug, gently undo them a turn, then tighten slightly. Keep working them back & forth increasing the undo stroke as you go. As you get to the end of the thread they 'can' be a bit of a pain, but just keep working them back and forth. Patience is key really, as you don't want to break one off in the head  ::)
I did 5 of em easy peasy, but as of the law of sod, there's always one really stiff one which I nearly bottled out of doing, I cracked it off a turn squirted some plusgas down it, left it for a while & it came out with a little persuasion  :o :o :o
« Reply #4 on: 21 November 2014, 17:13:09 »
Hmmm, are they a git then?  Only ever did glowplugs on the tractor, and they were no problem at all.
« Reply #5 on: 21 November 2014, 18:14:42 »
Not a bad job. DTi easy. Warm engine reduces risk of breaking one off but warm is fine, no need to have it scalding :y
henryd
  • west cornwall
« Reply #6 on: 21 November 2014, 18:17:19 »
They are normally easy on an iron head,the short ones on PSA diesels always seem to come out ok too,but I've had issues in the past with Astra / Zaffy ones :-\
other rides
