Author Topic: Running a cable to the rear aux socket  (Read 1284 times)
chrisgixer
« on: 24 November 2014, 10:31:26 »
....from the pas side foot well.
Is there room to run a cable past the gear change and hand brake, under the surround whatever it's called, under (?) the vents to the socket?
Does the surround need to come out? Or can I feed it thought with a coat hanger wire or similar?
Re: Running a cable to the rear aux socket
« Reply #1 on: 24 November 2014, 13:57:31 »
Piece of piss :y only seven screws and three clips... Ring for details and ffs don't use a coathanger ::)
chrisgixer
« Reply #2 on: 24 November 2014, 14:02:35 »
 ;D ok Al, ta ;D
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #3 on: 24 November 2014, 14:28:31 »
I tucked mine all the way under the plastic console lower edge where it meets the carpet and then up through the 12V accessory socket hole. Only bit I removed was the centre console armrest bit (screw each side) to gain access to the back of the aux socket plug. Took a couple of minutes.  :y
