Author Topic: manual transmission models  (Read 4075 times)
« on: 03 December 2014, 17:37:51 »
I really liked the omega in manual form.. however getrag 240 have longer 2nd and 3rd ratios  even with 3.90 diff..
after some search and questions to bmw mechanics I learned that the 2nd and 3rd gears can not be changed alone..  :-\
so I'm planning a change.. these are candidates for a swap
original
getrag 240
1st 3.72:1
2nd 2.02:1
3rd 1.32:1
4th 1.00:1
5th 0.81:1
R 4.10:1
getrag 260
1st 3.83:1
2nd 2.20:1
3rd 1.40:1
4th 1.00:1
5th 0.81:1
R 3.71:1
Getrag 250
1st 4.23:1
2nd 2.52:1
3rd 1.66:1
4th 1.22:1
5th 1.0:1
ZF 320/310
1st 4.2:1
2nd 2.49:1
3rd 1.67:1
4th 1.24:1
5th 1.0:1
R 3.9:1
also some of those boxes stays a bit tilted and cross  member and arms may need to be modified
so whats your opinion ?
« Last Edit: 03 December 2014, 17:40:18 by cem »
The Sheriff
Re: manual transmission models
« Reply #1 on: 03 December 2014, 17:57:47 »
With the getrag 250 or the ZF, fuel economy would suffer badly at motorway speeds. A 1:1 ratio in top gear would mean you'd be thrashing it at high speeds. On the other hand, if you plan to drag race your omega..... ;D
« Reply #2 on: 03 December 2014, 18:02:31 »
when I see you answered to the thread I could guess what kind of  answer I will have ;D
2nd and 3rd gear ratios are really desperate so must change..
however,  if I buy getrag 250 I still hope I can play with the 5th gear :-\
« Reply #3 on: 03 December 2014, 20:28:38 »
I drive an Auto, so don't have such complications to worry about; life is too short!.......... ::) ::) ;)
SMD
  • London
    • :( nowt
« Reply #4 on: 03 December 2014, 20:30:17 »
Has someone hijacked STEMOS account? Is that you Mark?
« Reply #5 on: 03 December 2014, 20:35:09 »
I would swap the internals with those from the Getrag 260... the reason being that it achieves what you're looking for with 2nd and 3rd but leaves 5th as an over drive. Without this, your fuel economy on a run will sky rocket and after five minutes on a motorway you'll also be deaf...
Try driving your car at motorway speeds in fourth if you're not convinced :y
« Reply #6 on: 03 December 2014, 20:52:19 »
reasonable.. Thanks Al :y :y :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #7 on: 05 December 2014, 18:05:17 »
I wouldn't listen to them. One of their employees told you yesterday that the diesel auto was better than the manual but you wouldn't listen.  ;) :-X
« Reply #8 on: 05 December 2014, 22:29:20 »
as I said there is no matching manual box.. if it will be, we will talk that..
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #9 on: 05 December 2014, 23:05:21 »
Just fit the proper transmission and forget about it.
chrisgixer
« Reply #10 on: 05 December 2014, 23:43:21 »
That's certainly true in omegas. The manual is antiquated steam powered and Edwardian all at once. Hateful device. Shoveling coal is a better experience ;D
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #11 on: 05 December 2014, 23:48:55 »
I've only had the displeasure of driving 2 Manual Omega's.  One was a 2.0 GLS and the gear change was akin to playing Cricket on the Wii.  The second was a properly sorted 3.0 MV6 and it was fun, but the gear change was the same.
It's a lardy arsed car, built for cruising, not for hooning.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #12 on: 05 December 2014, 23:53:48 »
And if you have played Cricket on the Wii, you have certainly broken some furniture, knocked glasses off the table, shattered some windows and generally made yourself look like a complete cock..... Much like throwing the gear lever somewhere near where you think the gear is, missing it, knocking the magic tree off the rear view mirror, punching the windscreen so it breaks and your mates laughing at you because you selected reverse instead of third!.
Exaggerating I may be, but that GM box is blooody awful!
chrisgixer
« Reply #13 on: 05 December 2014, 23:54:37 »
Hooning is purely set up dependant. Just some hoon better than others.
....but then, the others aren't as comfy. It's alright for those that can afford a Sunday play car, the rest of us have to make do with one car does all.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #14 on: 05 December 2014, 23:58:36 »
How right you are.
That's why I got out of Omega ownership.  I can only afford the one car, and needed something that would sit in the middle.  I have 90% of the comfort of an Omega (if anything, the seats are more comfortable, but it's a newer car) but it has rock hard suspension.  It goes like a stabbed rat, gives me good economy...... I just wished I picked up in the Saab long ago.  Dare I say it, more car for the money.
