wifi channels and 2.4g
Started by pauls, 04 December 2014, 20:05:35
pauls
Can anybody advise how I can change the 2.4g to 5g on the bthomehub5. I only want to change the tv conection so it will hopefully stream netflix quicker and better quality.
chrisgixer
I would of thought, if it's capable of 5ghz, it would transmit both 2.4 and 5 at the same time? No?
If so, and your device isn't seeing the 5ghz network then the device isnt 5ghz capable. As most older stuff isn't.
Broomies Mate
What hardware are you running?
Make and model of TV and Router?
pauls
Tv is a toshiba smart serial no, 82p21983. Taken from handbook "it is recommened to use ieee 802 11n on 5ghz for video and hd streaming.
The router is a bt homehub5.
chrisgixer
So 5ghz has to be activated.
How .... Queer ;D
The Sheriff
pauls
Right used the few technical brain cells I have and managed to change  the 5ghz to show itself on the tv. But I think due to the week signal strength it just drops off and then the tv wont find it. It only shows the 2.4ghz. Is there anyway of boosting the 5ghz. If not to get the same data transfer amout for hd tv would it be better to run a cable.
chrisgixer
Odd, our 5ghz is more stable than 2.4.
Might be worth running a cable to the ether net port on the tv. Something that I need to do for the amp and sky box, so may as well do the xbox and PS3 too, not that I use them any more.
The amp drops out after a couple of minutes regardless on wifi, the router is upstairs in the office.
....although we had an n900 wifi only router that worked much better than the Virgin standard superhub 2 we have now.
